Simple sketch for reading 4 Flow/Hall sensors with an Arduino Mega
// Read four Hall Flow sensors with Arduino MEGA
unsigned long lastmillis1 = 0;
unsigned long lastmillis2 = 0;
unsigned long lastmillis3 = 0;
unsigned long lastmillis4 = 0;
volatile int rpmcount1 = 0;//see http://arduino.cc/en/Reference/Volatile
int rpm1 = 0;
volatile int rpmcount2 = 0;
int rpm2 = 0;
volatile int rpmcount3 = 0;
int rpm3 = 0;
volatile int rpmcount4 = 0;
int rpm4 = 0;
void setup(){
  attachInterrupt(0, rpm_fan1, FALLING);//interrupt cero (0) is on pin 2.
  attachInterrupt(1, rpm_fan2, FALLING);//interrupt cero (1) is on pin 3.
  attachInterrupt(4, rpm_fan2, FALLING);//interrupt cero (4) is on pin 19.
  attachInterrupt(5, rpm_fan2, FALLING);//interrupt cero (5) is on pin 18.
void loop(){
  detachInterrupt(0);    //Disable interrupt when calculating
  rpm1 = (rpmcount1 * 60 / 7.5) * 0.264172;  /* Convert frequency to GPH, note: this works for one interruption per full rotation. For two interrups per full rotation use rpmcount * 30.*/
  lastmillis1 = millis(); // Uptade lasmillis
  attachInterrupt(0, rpm_fan1, FALLING); //enable interrupt
  detachInterrupt(1);    //Disable interrupt when calculating
  rpm2 = (rpmcount2 * 60 / 7.5) * 0.264172;  /* Convert frequency to GPH, note: this works for one interruption per full rotation. For two interrups per full rotation use rpmcount * 30.*/
  lastmillis2 = millis(); // Uptade lasmillis
  attachInterrupt(1, rpm_fan2, FALLING); //enable interrupt
  detachInterrupt(4);    //Disable interrupt when calculating
  rpm3 = (rpmcount3 * 60 / 7.5) * 0.264172;  /* Convert frequency to GPH, note: this works for one interruption per full rotation. For two interrups per full rotation use rpmcount * 30.*/
  lastmillis3 = millis(); // Uptade lasmillis
  attachInterrupt(4, rpm_fan3, FALLING); //enable interrupt
  detachInterrupt(5);    //Disable interrupt when calculating
  rpm4 = (rpmcount4 * 60 / 7.5) * 0.264172;  /* Convert frequency to GPH, note: this works for one interruption per full rotation. For two interrups per full rotation use rpmcount * 30.*/
  lastmillis4 = millis(); // Uptade lasmillis
  attachInterrupt(5, rpm_fan4, FALLING); //enable interrupt
  Serial.print("GPH1 =\t"); //print the word "GPH1" and tab.
  Serial.println(rpm1); // print the GPH value.
  Serial.print("GPH2 =\t"); //print the word "GPH2" and tab.
  Serial.println(rpm2); // print the GPH value.
  Serial.print("GPH3 =\t"); //print the word "GPH3" and tab.
  Serial.println(rpm3); // print the rpm value.
  Serial.print("GPH4 =\t"); //print the word "GPH4" and tab.
  Serial.println(rpm4); // print the rpm value.
  Serial.println("..........................");
  rpmcount1 = 0; // Restart the RPM counter
  rpmcount2 = 0; // Restart the RPM counter
  rpmcount3 = 0; // Restart the RPM counter
  rpmcount4 = 0; // Restart the RPM counter
void rpm_fan1(){ /* this code will be executed every time the interrupt 0 (pin2) gets low.*/
  rpmcount1++;
void rpm_fan2(){ /* this code will be executed every time the interrupt 0 (pin2) gets low.*/
  rpmcount2++;
void rpm_fan3(){ /* this code will be executed every time the interrupt 0 (pin2) gets low.*/
  rpmcount3++;
void rpm_fan4(){ /* this code will be executed every time the interrupt 0 (pin2) gets low.*/
  rpmcount4++;
I couldn't find a sketch to read 4 of these at once so i managed to cut and paste one together that was originally for reading motor rpm. I added a conversion to Gallons per hour but it can be configured for whatever. Here is the link to the original article.
http://forum.arduino.cc/index.php?topic=217666.0
You need a 10k pull up resistor on each of the signal wires.
I solved this problem by writing a new FlowCounters library to support multiple flow meters. It is here:
http://forum.arduino.cc/index.php?topic=236326.0
