Simple sketch to interface with any thermistor and get accurate readings
This is a simple sketch I wrote to Interface any Thermistor with an Analog pin on an Arduino compatible Microcontroller. When I began trying to use thermistors with my Arduino I was unable to find a simple program ( easy to follow) to suit my needs. I did the only thing I could and created my own. I am posting it here for those in the same boat as I was. If you have any suggestions to improve my code please reply and re-upload.
Link: https://app.box.com/ArduinoThermistorSketch
Thanks
Ian Bowler
ThermistorD.ino (977 Bytes)
looks good, did some restyling of your code, added a header for meta data,
some spaces and empty lines to mimic logical blocks.
//    FILE: .ino
//  AUTHOR:
// VERSION: 0.1.00
// PURPOSE:
//    DATE: 2014-
//     URL:
// Released to the public domain
#define THERMISTORPIN   A0
// STEINHART CONSTANTS
// from http://www.thinksrs.com/downloads/programs/Therm%20Calc/NTCCalibrator/NTCcalculator.htm
#define A -1.392873556E-3
#define B  6.280201199E-4
#define C -12.96450742E-7
#define REFV 5
#define SERIESRESISTOR 10000
#define ADJUST 0
void setup(void)
  analogReference(INTERNAL);    //Default INTERNAL if EXTERNAL connect AREF pin
void loop(void)
  float raw = analogRead(THERMISTORPIN);
  float analogvoltage = raw / 1024 * REFV;
  float resistance = SERIESRESISTOR * (1/((REFV/ analogvoltage)-1));
  float logcubed = log(resistance);
  logcubed = logcubed * logcubed * logcubed;
  float kelvin = 1.0 / (A+B*log(resistance)+C*(logcubed));
  float fahrenheit = (((kelvin - 273.15) * 9.0 / 5.0 + 32.0)+ ADJUST);
  Serial.print("temp *F = ");
  Serial.println(f);
instead of the #define you can also use e.g. const float A = -1.392873556E-3;
this gives the compiler just a little more information especially with the integer/long/unsigned etc.
Next step is to create a function like this
// reads a thermistor connected to pin P
// returns temperature in Celsius.
float readThermistor(pin p)
  ... (replace this with the real code)
  return temp;
to make a reusable piece of code
