simple still camera
I am trying to have an arduino take 5-15 still pictures in a 10 second span.
Raspberry pi, buy the camera and run raspistill on an interval - easy as pie. Arduino, so many options and possibilities! I like the flexibility, but it can be a little overwhelming. I plan on storing to a microsd fat16, easy enough. But the rest is totally open - type of camera, ntsc vs pal, i2c, spi whatever. Where should I start? What is an easy and reasonable way to accomplish this!
Thanks!
Start by browsing the forum and see what others have done. I think OV760 is a camera that will take still shots and has a library for arduino to capture the picture.
OV7670
Look at this too http://www.ladyada.net/make/IoTcamera/
You haven mentioned if you have the interface cable. Do you plan to purchase a female jack to plug the audio cable into and wire the jack to the arduino ? (somehow)
Are you responding in the right place? What does audio have to do with still shots?
The shutter release cable is a standard mono plug commonly used for audio. It's not an "audio" cable, it's a cable with mini plugs on it . Most photographers would know I meant the shutter cable. Let's just call it a mono mini plug. (I don't know the size)
I think we're talking different cameras then. You're suggesting controlling the shutter of a commercial, complete camera like a Nikon or something it seems. I'm suggesting the camera guts that one integrates into a design, and can extract the content of a picture from.
I've never heard of that . Do you mean like a GO PRO ?
For mine, see the adafruit link I posted. For yours, many cameras & flash units can be triggered by pulling a pin low.
Oh, ok. That's like an inexpensive FPV Quadcopter camera. except it can' t be used for flight control because it isn' t video.
raschemmel:
Let's call it a "stereo mini plug (2.5mm)"
Are you sure it's stereo ? Shutter release is an SPST application. There would be no reason to use a stereo plug if all you want to do is close a single set of contacts.
My DSLRs have 2.5mm stereo jacks - one set of contacts for focus, and the other for shutter release.
Ok. That makes sense. Thanks for the clarification.
