Simple switching circuit to pulse a motor?
So essentially what I am doing here is powering a small motor via a "digital" switch. What I would like to happen is that once the motor is switched on the motor is on for 7 seconds then off for 7 seconds continuously forever. If the switch is pressed then the motor and the cycle stops.
If the switch is pressed again then the whole thing kicks off again.
I am sure this should be really quite straight forward ? any help appreciated. I am not too sure how to interrupt the delay function?
int QTCPin = 12;      // select the input pin for the switch
int MotPin = 11; // select the outpin for the Motor circuit
int QTCval ;      // variable to store the value coming from the switch
  pinMode(QTCPin, INPUT);  // declare the Switch as an INPUT
  pinMode(MotPin, OUTPUT); //declare the Motpin as an OUTPUT
   QTCval = digitalRead(QTCPin);    // read the value from the PIN
   Serial.println(QTCval);
 if(QTCval== HIGH)
          {digitalWrite(MotPin, HIGH);
          delay (1000*7);
          digitalWrite(MotPin, LOW);
           delay (1000*7);
    }else{
delay(100);
