Simple TCP communication
I am new to arduino I am trying to some something seemingly simple but I need some help
I am basically trying to send commands to a device from the device manual the command should be as follows
MONITOR A: [CR]
Identify: true[CR]
[CR]
The way i understand it is the command wont take until it get the blank CR I am modifying a program I found on the Web, where the guy uses the serial monitor to send a command, I simply added my command string to where he sends the data typed in the serial monitor, that seemed to work albeit i get an error message saying syntax error from the monitor, becasue of the letter i typed on the serial monitor
here is the code
#include <SPI.h>
#include <Ethernet.h>
/**** DEFINITION DES VARIABLES ****/
// Adresse MAC de la carte Ethernet
byte mac[] = { 0x90, 0xA2, 0xDA, 0x0D, 0x9E, 0x16 };
// Adresse IP de la carte Ethernet si pas DHCP
byte ip[] = { 192,168,0,222 };
// Adresse du chassis SNELL
byte rollcall[] = { 192,168,0,2 };
// Client Ethernet
EthernetClient clientRollCall;
// Varible réception série
String code;
/**** SETUP DU SYSTEME ****/
// Ouvre la connexion série pour la console
    Serial.println("Connection Serie etablie");
    Serial.println("Vitesse du port 9600 bps");
// Connection Ethernet
  Ethernet.begin(mac,ip);
    Serial.println("Connection IP en cours ...");
     if(clientRollCall.connect(rollcall, 9992 )) {
       Serial.println("Connection au chassis SNELL etablie.");
       clientRollCall.connect(rollcall, 9992);
          delay(100);
          clientRollCall.println("MONITOR A:");
          delay(100);
          clientRollCall.println("Identify: true");
          delay(100);
          clientRollCall.println();
          delay(100);
     else {
       Serial.println("Echec de la connection au chassis SNELL.");
/**** CONVERSION RS232 > IP ****/
void loop(){
  // Lecture des données entrantes sur le port série (Arduino Uno).
  // Changer numéro de port si Board différente du UNO.
  // Nécessite une interface TLL vers RS232.
  if(Serial.available()){
    char incomingString = Serial.read();
       if (code.equals("none")){
          Serial.println("Aucune commande recue");
          Serial.println("Commande recue :"+incomingString);
          //clientRollCall.stop();
    delay(100);
  if(clientRollCall.available()){
    char c = clientRollCall.read();
    Serial.print(c);
  while (Serial.available() > 0) {
    char inChar = Serial.read();
    if (clientRollCall.connected()) {
      clientRollCall.print(inChar);
      Serial.print(inChar);
          clientRollCall.println("");
so right at the very end the following line
      [code]Serial.print(inChar);
takes what you type and sends it to the monitor, so i tried deleting that line and it doesnt work anymore after some trial and error, it seems that on the bottom corner of the serial monitor you have an option for BOTH NL and CR if thats enabled it works mainly the NL, if i put the
Serial.print(inChar); it works as long as the NL is enabled so i take it it needs an new line in order for the command to take, how do i do that using the client.print or println command?
Thank you[/code]
We don't deal with mystery devices here. A link to the device is necessary.
The println() method adds a carriage return and line feed to the text being sent. If that is not what the mystery device expects, you can use \r or \n at the end of the text, and the print() method, instead.
http://www.blackmagicdesign.com/products/smartview/techspecs
It's a monitor. I got it to work by sending the command in hex with a client.print
when you say \r or \n after the text or in the quotes?
clientRollCall.println("MONITOR A:"\r);or clientRollCall.println("MONITOR A: \r");
this clientRollCall.write(0x0A) after the command seemed to work i seen sample code where they use clientRollCall.println(""); but that didnt work for me
they way i understand it println adds a CR , print doesnt but write i dont quite get
Yes. After the text, in the quotes.
The write() method is for sending binary data. What you send is what you get; nothing is added; nothing is removed.
