simple tetris script
is there a way to make a very simple 1 dot tetris script, that uses very few lines?
i was thinking of using arrays, and replacing the value with an integer which i would control via button press
for example:
int val = 0;
int TEST[] = 0, 1, 2, 3, 4....
( or however you put arrays in ) and replace a value inbetween the "[]" with val, and then set val to change from a button press.
so i want the script just to move 1 led, as a test, around a 5 x 7 screen. if possible, making it so the led's are connected to 2 shift registers. the ones i talk about so much... lol ( i believe 74hc sumthin ) and the movement is controlled by 4 buttons, that can be connected to any arduino pins, or maybe to make it intresting, using 2 potentiometers!
im very curious to hear what you guys come up with, and i'm really not sure how to approach this, so please, if you can, AYUDAME! ( or "help me" in spanish lol )
nobody?
well if it is 1 dot tetris you will really only need two buttons, right and left because rotation of a single pixel is irrelevant
there is some sample code here,on a tetris engine... I havent read it, but google can be your fiend for things like this. http://www.mit.edu/people/nathanw/java/TetrisSrc.html
It is really just the simplest form of collision detection.
ok, how about this;
can i make an array and then call back an integer from the array buy pressing the button?
so like an example:
this isint real code, but go with it…;
array is “ledarray 1-9”
and i make it so val is 0
and one button press makes val ++ by 1, and another button makes val – by 1
and then i make “ledarray[val]”
can i make ledarray bring up the led value by the val?
and of course with a matrix, i would need to turn it into coordinates, instead of only left and right…
many ways to do this, this is off the top of my head
a two dim array for the entire board
start with your pixels off screen position, somewhere at max x +1,y ... randomize y
before moving your pixel check the position x,y-1 against the two dim array.
if that spot is empty, set the position to x,y-1 else add x,y to arraylist reset pixel position to top value(max x +1, random y)
refresh the leds to display your 2 dim array
then use interrupts for button pushes... should just modfy the x value... you can decide if it wraps or the right/left edges are boundraies.....
actually this is starting to sound interesting to me....
maybe two of these stacked for the leds? http://www.sparkfun.com/commerce/product_info.php?products_id=759
