Simple Thermocouple Sketch Gone Wrong
Hey guys new the wonderful world of Arduino, I am having trouble with a simple setup to test my Type K thermocouple and AD595 amplifier.
With my voltmeter I am reading a +/-10uV fluctuations due to temperature plus a reading of 270mV which according to the tables is around 27 C. The AD595 and thermocouple are operating as they should.
I have tried a few different setups on the arduino end:
1.) Analog input with no external voltage reference tied to AREF. 2.) Analog input with external voltage (5.54V) to AREF. I followed the reference usage directions:
  • Defined my analogReference(EXTERNAL);
  • Included: #define ANALOG_VOTLAGE_REFERENCE 5.5 3.) In either case I get similar results:
Either the readout on the serial monitor is 0.00 with the reference tied in, or it cycles wildly through up to 1023 and then back to zero.
What I am not understanding is how I can read the correct values at the analog input terminal but even when I just print the raw serial data using Serial.Print(analogRead(0)); I get either zero or wild cycling. Shouldn't I see 270 or so if I just printed the raw AI value?????
Here is the example test sketch PLEASE HELP I'm drowing over here, and I know I am missing something really simple.
float myVal; //#define ANALOG_VOTLAGE_REFERENCE 5.5
void setup() { // analogReference(EXTERNAL); Serial.begin(9600);
void loop() { myVal = analogRead(2); Serial.print(myVal); // Serial.println((5.54 * myVal) /1024);// just change 5 to 4.87 delay(1000); }
Some links to the hardware you have would be useful. So would a schematic or picture of how it is all connected. The grounds are all connected, right?
AD595:
http://www.analog.com/en/sensors/analog-temperature-sensors/ad595/products/product.html
Type K Thermocouple:
http://www.sparkfun.com/commerce/product_info.php?products_id=251
I followed the schematic from here:
http://www.arduino.cc/playground/Main/BBCCschematics
Grounds are all connected as shown.
I am using the 328 arduino
No fret figured it out, I feel dumber and smarter at the same time, thanks though.
What was the solution? It may help others in the future :)
