Hi, I need assistance in programming at timed switch.
When I close a switch, I need an LED to light up for 50ms, then turn off (even though the switch is still closed). When I open the switch and close it again, this needs to repeat.
What I am doing is more complicated than this, but the concept is the same.
const byte pinLED = LED_BUILTIN; //define LED pin
const byte pinSwitch = 2; //switch input (pressed == LOW)
unsigned long
timeLED;
byte
lastSwitch; //keep track of what the switch "was' so we can detect a change
#define OFF false //makes code a little easier to read
#define ON true
bool
bstateLED; //internal tracker of LED state (on or off)
//set up the switch pin as input pullup
pinMode( pinSwitch, INPUT_PULLUP );
lastSwitch = digitalRead( pinSwitch ); //read the state of the switch to establish a value for the first loop() check
//setup the LED
pinMode( pinLED, OUTPUT );
digitalWrite( pinLED, LOW );
bstateLED = OFF;
}//setup
byte
currSw;
//read the switch...
currSw = digitalRead( pinSwitch );
//...if it's not the same as the last read...
if( currSw != lastSwitch )
//make the curr the last
lastSwitch = currSw;
//if the curr is low the button was pressed (high-to-low transition)
//if the LED is off right now, turn it on and start timing a 50mS period
//if the LED is already on, just ignore this press
if( currSw == LOW && bstateLED == OFF )
digitalWrite( pinLED, HIGH );
bstateLED = ON;
timeLED = millis();
}//if
}//if
//if the LED is on now, see if it's time to turn it off
if( bstateLED == ON )
//time elapsted >= 50mS?
if( (millis() - timeLED) >= 50 )
//yes; turn off the LED and set the internal flag to 'off'
bstateLED = OFF;
}//if
}//if
}//loop
That example shows you very specifically how to detect when a switch BECOMES closed. From that you can figure out how to detect when it BECOMES open. That information will tell you when it's time to turn on the LED.
