Simple timer program problem
Hello all,
I'm new to arduino but have managed to piece together a timer program to control some blinds.
I want to rolldown at night and rollup in the morning to conserve heat in winter.
My problem is the rolldown operation. When I upload the program to my arduino uno with Sainsmart 8 channel relay it will drive my 12vdc motor and rollup then rolldown when I set the times only a few minutes apart. When i set it for morning and evening it works every morning but never does the rolldown at 19:00 hrs. I have a RTC DS1307 connected to the arduino.
Anyway, I can't find any problem with the programming but it doesn't make sense that it works when I set times close together but not when I set what I would like it to be
Any help would be appreciated, I'm lost :~
#include <Wire.h>
#include <RTClib.h>
RTC_DS1307 RTC;
int output3 = 3;         // Set our output pin
int output4 = 4;         // Set our output pin
//rolldown bytes
byte startHour = 19;    // Set our start and end times
byte startMinute = 38; // set start minute
byte startSecond = 0; // set start second
byte endHour = 19;      // Use 24h format for the hour, without leading zero
byte endMinute = 42;   // set end minute
byte endSecond = 0;   // Set end second
//rollup bytes
byte startHour2 = 7;    // Set our start and end times
byte startMinute2 = 1; // set start minute
byte startSecond2 = 0; // set start second
byte endHour2 = 7;      // Use 24h format for the hour, without leading zero
byte endMinute2 = 5;   // set end minute
byte endSecond2 = 0;   // Set end second
//rolldown
byte validStart = 0;    // Declare and set to 0 our start flag
byte poweredOn = 0;     // Declare and set to 0 our current power flag
byte validEnd = 0;      // Declare and set to 0 our end flag
//rollup
byte validStart2 = 0;      // Declare and set to 0 our end flag
byte poweredOn2 = 0;      // Declare and set to 0 our end flag
byte validEnd2 = 0;      // Declare and set to 0 our end flag
void setup () {
  pinMode(output3, OUTPUT);   // Set our relay as an output pin
  digitalWrite(output3, LOW); // Set the output to LOW (off)
  pinMode(output4, OUTPUT);   // Set our output as an output pin
  digitalWrite(output4, LOW); // Set the output to LOW (off)
  Wire.begin();              // Start our wire and real time clock
  RTC.begin();
  if (! RTC.isrunning()) {                       // Make sure RTC is running
    Serial.println("RTC is NOT running!");
    //RTC.adjust(DateTime(__DATE__, __TIME__));  // Uncomment to set the date and time
void loop () {
  DateTime now = RTC.now(); // Read in what our current datestamp is from RTC
  //if (now.second() == 0) // Only process if we have ticked over to new minute
  if (poweredOn == 0) {  // Check if motor currently powered on
    checkStartTime();    // If they are not, check if it's time to turn it on
  else {
    checkEndTime();      // Otherwise, check if it's time to stop roll
  if (poweredOn2 == 0) {  // Check if lights currently powered on
    checkStartTime2();    // If they are not, check if it's time to turn on
  else {
    checkEndTime2();      // Otherwise, check if it's time to turn off
  if (validStart == 1) { // If our timer is flagged to start, roll down
    rolldown();
  if (validEnd == 1) {   // If our time is flagged to end, stop roll
    stoproll();
  // start rollup
  if (validStart2 == 1) { // If our timer is flagged to start, rollup
    rollup();
  if (validEnd2 == 1) {   // If our time is flagged to end, stop roll
    stoproll();
  delay(750);
byte checkStartTime() {
  if (now.hour() == startHour && now.minute() == startMinute && now.second() == startSecond) {
    validStart = 1;  // If our start hour and minute match the current time, set 'on' flags
    poweredOn = 1;
  else {
    validStart = 0;  // Otherwise we don't need to power up the motor
  return validStart; // Return the status for powering up
byte checkEndTime() {
  if (now.hour() == endHour && now.minute() == endMinute  && now.second() == endSecond) {
    validEnd = 1;    // If our end hour and minute match the current time, set the 'off' flags
    poweredOn = 0;
  else {
    validEnd = 0;    // Otherwise we don't need to power off the motor yet
  return validEnd;   // Return the status for powering off
byte checkStartTime2() {
  if (now.hour() == startHour2 && now.minute() == startMinute2 && now.second() == startSecond2) {
    validStart2 = 1;  // If our start hour and minute match the current time, set 'on' flags
    poweredOn2 = 1;
  else {
    validStart2 = 0;  // Otherwise we don't need to power up the motor yet
  return validStart2; // Return the status for powering up
byte checkEndTime2() {
  if (now.hour() == endHour2 && now.minute() == endMinute2  && now.second() == endSecond2) {
    validEnd2 = 1;    // If our end hour and minute match the current time, set the 'off' flags
    poweredOn2 = 0;
  else {
    validEnd2 = 0;    // Otherwise we don't need to power off the motor yet
  return validEnd2;   // Return the status for powering off
void rolldown() {
  digitalWrite(output4, HIGH);
  ;  // roll down cover
void rollup() {
  digitalWrite(output3, HIGH);
  ;  // roll up cover
void stoproll() {
  ;  // roll up cover
  ;  // roll up cover
Your code seems to depend on an exact match of the hour, minute, and second, which seems to be unrealistic if your loop( ) might ever take more than a second to run.
your code also returns values which are global variables. This is not good practise.
You either modify global values in your functions, or you return the result. Doing both might cause confusion.
