simple touch-initiated fade code inquiry
Hi there! Still terribly unfamiliar with Arduino, but would like some help with a simple project to better my understanding. I'm trying to code a touch sensor-activated light that, instead of turning on immediately, fades on and fades off when the hand leaves the sensor. I've so far figured out the on/off part:
const int analogInPin = A0;
const int analogOutPin = 9;
int sensorValue = 0;
int fadeValue = 0;
  pinMode(analogOutPin, OUTPUT);
void loop(){
  sensorValue = analogRead(analogInPin);
  analogWrite(analogOutPin, fadeValue);
  if(sensorValue > 50)
    digitalWrite(analogOutPin, HIGH);
    digitalWrite(analogOutPin, LOW);
I've been trying to incorporate the example fade code into mine but to no avail. I'd really appreciate any and all advice/help!
alittlebigadventure
Please show us your attempt to incorporate the fade code.
hi,
here was my attempt for the fade code. I tried to put the for loop code into my touch code but it doesn't work that well.
const int analogInPin = A0; // Analog input pin that the potentiometer is attached to
const int analogOutPin = 9; // Analog output pin that the LED is attached to
int fadeValue = 0;
pinMode(analogOutPin, OUTPUT); // declare LED as output
void loop(){
if(sensorValue < 50)
analogWrite(analogOutPin, LOW);
for (int fadeValue = 0 ; fadeValue <= 255; fadeValue += 2) {
//digitalWrite(analogOutPin, HIGH);
delay(30);
Are you trying to implement a touch-on/touch-off kind of functionality? That would require a state change detection. Right now the output just tracks the input. You need to specify what you expect, and what you are seeing. "Doesn't work that well" doesn't help us understand your problem.
There are four states - off, on, fading up and fading down. Work out what should trigger
transitions between them and when. For instance do you want to respond to input during
a fade or let the fade complete? Draw out all the possibilities and make them explicit in
your thinking.
Following on from MarkT. I like to set global variables like...
enum states {TS_ON, TS_FADING_OFF, TS_OFF, TS_FADING_ON} switchState = TS_OFF
and then in loop you can use a switch statement like....
  int sensorValue=analogRead(analogInPin);
  switch (switchState){
    case TS_ON:
      if (sensorValue>50){
        //set switchState=TS_FADING_OFF
        //do stuff to start fading off
    case TS_FADING_OFF:
      //fad off
      //when off set switchState=TS_OFF
    case TS_OFF:
        //set switchState=TS_FADING_ON
        //do stuff to start fading on
    case TS_FADING_ON:
      //fad on
      //when on set switchState=TS_ON
