Simple typecasting question
How's it going?
I have a hopefully-simple scenario involving typecasting.
Here's what I have:
double input = myCooler.getInput();
int conversion = (int)input;
uint8_t conv = (uint8_t)conversion;
SPDR = conv;
myCooler.getInput() is just a function that returns a double.
The SPDR register on my Arduino holds unsigned 8 bit integers at the minimum (and, conveniently, is all I need for my project.)
Can I write the above code like this instead, or is it bad practice? (Mind you, I don't need those variables after that chunk of code executes.)
SPDR = (uint8_t)((int)myCooler.getInput());
,sknahT
ynohtnA
You can say "SPDR = myCooler.getInput();" and the compiler will do the conversion for you. You need to use casting only when the default conversions won't work. When you assign a 'double' to a 'byte' the 'double' gets converted to 'int', then truncated to 'char' then cast to 'byte' (unsigned char).
I found this very interesting, short but to the point :
https://learn.sparkfun.com/tutorials/data-types-in-arduino
Interesting, so just to clarify, with your suggestion, 4.84 becomes 00000100 ?
To add on, there is a scenario where I need to discern what I initially wrote about ‘getting the input’ from another type of input. I do this by adding 64 to the value of the input, so the master on the receiving end of the transfer can know the difference between incoming data.
So, ( myCooler.getInput() + 64 ) becomes 01000100, correct?
Try it out in a simple test sketch. What happens?
If you store 4.84 in an integer type you will get the value 4.
If you store the expression 4.84 + 64 in an integer type you will get the value 68.
You could simply say:
uint8_t input = (uint8_t)myCooler.getInput();
And cut the extra steps in between.
Power_Broker:
Yes, however it has been suggested that you can cut that out and say:
uint8_t input = myCooler.getInput();
But the question should be asked, why does myCooler.getInput() return a double? If it ever does return values over 255, any of these casts could result in a hidden bug. A major advantage of a cast is that it is explicit.
lennon-pledge:
No, 4.84 does not become 64 (which is what the octal constant 00000100 represents), it becomes 0b0100,.or more simply 4
