What happens?
What happens now?
You get hold of a copy of Horowitz and Hill, and you read it.
What happens?
What happens now?
AWOL:
What happens?
What happens now?
Thank you for this fantastic suggestion! I have a great suggestion to you too...
Mike?
Wire it up correctly. If it gets hot you have not.
Can you post a picture of your setup?
Now I wired back to the prew state but at this time the IC is hot and doesnt work... =(
CAn I make any harm in my arduino? How can i test it?
And I check again and again but my schematic looks like what you drew.
IF you don't wire it up right you can.
How can I tell if you have wired it up if you don't post a photo?
What IC is this then, one in the arduino or the digital pot?
My digital pot is fire hot.
I dind't do anything just cut off the vss line from the gnd and solder the 220V-USB converter between the two wire. The +5 went the gnd and the supply gnd to vss pin.
What happens if I swap the gnd with the +5V? Is it any way to life up this Sigital pot?
What part of:-
Do you not understand.
Your chip will get very hot and probably burn!
