It is easy (using an LM317) to create a voltage that can be used to charge a single LiPo.
I thought (incorrectly) that I could use two LM317s stacked one on the other to create a simple balanced charger for a pair of LiPo cells connected in series. But that does not work because the output of the lower LM317 cannot act as a sink for current from the top one.
I have come across circuits that provide a virtual ground using an LM317 and an LM337 - but they seem to be only capable of dividing the voltage in half - hence 12v would give 2 x 6v and I would need a third regulator to step down the 12v to 8v before halving that. This seems to me to be getting too complicated and it would be easier (although there is a delay) to buy a ready-made 2S LiPo charger.
I am just posting here in case someone is aware of a simple circuit that I can use to give me two stacked regulated voltages from a single 12v supply?
I have had great success over the past couple of years using LiFePO4 cells .... gotten rather inexpensive due to their extensive use in evening lights for home gardens and other solar tidbits.
Nice about LiFePO4 is they can be float-charged on 3.3 to about 80% - 90% or if the hardware can deal with 3.45V then very nearly 100%. I just use an under $1 DC-DC buck, set it to around 3.4V on the output, hook up the ESP8266 or STM32F103 board, and parallel the battery.
LiFePO4 nevers has a cycle chemistry that produces lithium metal. The cells can toleration abuse in both discharge and charging. They are not expensive IMO:
You can fine-tune your DC-DC buck output voltage to lower the trickle to around 1 to 5mA when the cell is fully charged and the device is OFF. With the device ON, if the batteries are supplying more than a few mA, then you have a "sag' in your wiring from the DC-DC to the batteries. Size the DC-DC to handle the full project plus whatever 1C of the battery capacity is rated.
Do properly fuse the batteries. With the DC-DC not having an external supply, the battery should be switched to avoid the circuitry running the cell down below about 2V. No diode is required from the DC-DC since the module has its own output side diodes. The output caps on the DC-DC also parallel the battery, so you get the benefit of almost no switch-on battery sag.
LarryD: @Robin2
This may help:
[Planning an implimenting](http://Planning an implimenting)
. Currently working my way through this in the hope of making my new project a goer. No doubt will have a query or two along the way .....thanks Robin2
