Hello all,
I have put together a simple project with an Arduino Nano, a ESP8266 microcontroller (using Wi-fi, not using it as a controller) and a DS18B20 waterproof temperature sensor.
Everything works as I can get temperature readings properly, and my web server is able to provide the readings to a client as a JSON but it works only after the first time; subsequent calls just sit there and eventually the ciient times out (the --ignore-content-length doesn't seem to help):
curl --verbose http://192.168.1.12:80
* Trying 192.168.1.12:80...
* Connected to 192.168.1.12 (192.168.1.12) port 80 (#0)
> GET / HTTP/1.1
> Host: 192.168.1.12
> User-Agent: curl/7.71.1
> Accept: */*
* Mark bundle as not supporting multiuse
< HTTP/1.1 200 OK
* no chunk, no close, no size. Assume close to signal end
* Closing connection 0
23.19
I noticed than my debug printouts using the serial port sometimes get mangled, both with the serial monitor on the Arduino IDE 2 and minicom --baudrate 115200 --device /dev/ttyUSB0 (I'm coding on Linux).
08:15:45.964 -> AT+CIPSERVER=1,80
08:15:45.964 ->
08:15:45.964 -> OK
08:15:49.370 -> ,76:GET / HTTP/1.1
08:15:49.402 -> Host: 193.168.1.12
08:15:49.402 -> User-Agent: curl/7.71.AT+CIPN
HRVP/1.1 80 OK
C�# ��
08:15:50.397 -> SEND OK
08:15:53.413 -> AR)��PALO�QOj
08:15:53.413 -> 0,CLOSED
08:15:53.413 ->
08:15:53.413 -> OK
I managed to send AT commands with these settings (115200 8N1 | NOR) and the output doesn't break when doing that.
The code of the web server is pretty simple, maybe I do have a connection problem (but then how does it work fine the first time?):
* Simple webserver that captures temperature using a DST18B20 sensor and relays the results to a ESP8266 microcontroller
* through an Arduino Nano board.
#include <SoftwareSerial.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#define DEBUG true
#define ONE_WIRE_BUS_PIN 2
#define PORT_SPEED 115200
#define IC_SENSOR_IDX 0
#define SLEEP_ONE_SEC 1000
#define HALF_SEC 1500
#define TWO_SEC 2000
#define THREE_SEC 3000
#define RX_PORT 10
#define TX_PORT 11
SoftwareSerial esp8266(RX_PORT, TX_PORT);
OneWire oneWire(ONE_WIRE_BUS_PIN);
DallasTemperature sensors(&oneWire);
Serial.begin(PORT_SPEED);
sensors.begin();
esp8266.begin(PORT_SPEED);
InitWifiModule();
if (esp8266.available()) {
if (esp8266.find("+IPD,")) {
sensors.requestTemperatures();
float temp_c = sensors.getTempCByIndex(IC_SENSOR_IDX);
float temp_f = sensors.getTempFByIndex(IC_SENSOR_IDX);
delay(SLEEP_ONE_SEC);
int connectionId = esp8266.read() - 48;
String webpage = R"(HTTP/1.1 200 OK
Content-Type: application/json
Connection: close
webpage.concat("{\"celcius\": \"");
webpage.concat(temp_c);
webpage.concat("\", \"farenheit\": \"");
webpage.concat(temp_f);
webpage.concat("\"}\r\n");
webpage.concat(R"(
const int webpage_length = webpage.length();
String cipSend = "AT+CIPSEND=";
cipSend.concat(connectionId);
cipSend.concat(",");
cipSend.concat(webpage_length);
cipSend.concat("\r\n");
sendData(cipSend, SLEEP_ONE_SEC, DEBUG);
sendData(webpage, SLEEP_ONE_SEC, DEBUG);
String closeCommand = "AT+CIPCLOSE=";
closeCommand.concat(connectionId);
closeCommand.concat("\r\n");
sendData(closeCommand, THREE_SEC, DEBUG);
String sendData(String command, const int timeout, boolean debug) {
String response = "";
esp8266.print(command);
long int time = millis();
while ((time + timeout) > millis()) {
while (esp8266.available()) {
char c = esp8266.read();
response += c;
if (debug) {
Serial.print(response);
return response;
void InitWifiModule() {
sendData("AT+RST\r\n", TWO_SEC, DEBUG);
sendData("AT+CWJAP=\"XXXX\",\"YYYY\"\r\n", TWO_SEC, DEBUG);
delay(3000);
sendData("AT+CWMODE=1\r\n", HALF_SEC, DEBUG);
delay(1500);
sendData("AT+CIFSR\r\n", HALF_SEC, DEBUG);
delay(1500);
sendData("AT+CIPMUX=1\r\n", HALF_SEC, DEBUG);
delay(1500);
sendData("AT+CIPSERVER=1,80\r\n", HALF_SEC, DEBUG);
I can share the schematics here but this smells like a coding issue to me, my questions are:
- There are any libraries I can use to simplify my code? I want it to be more reliable, happy to trade speed over proper working.
- I do not want to use the ESP8266 controller directly. I'm aware of plenty of projects and examples that support that mode of operation but I want to extend my Arduino Nano, not replace it with the ESP8266 controller.
- I looked through the forums and I could not find a use case similar to mine, apologies if this was answered before and I missed it.
Thanks,
