Simple Webserver on Portenta Machine Control
Does anyone know how to setup a webserver for Portenta Machine Control for remote monitoring?
There is no documentation or existing example yet.
I tried this sketch and there is no error in the output. But I typed in the IP address in the web browser and there's no response. I ping the IP address and there is no response as well.
Not sure if I'm missing anything.
Here is the sketch
#include <Arduino_MachineControl.h>
#include <WiFi.h>
#include "arduino_secrets.h"
using namespace machinecontrol;
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
char ssid[] = SECRET_SSID;    // your network SSID (name)
char pass[] = SECRET_PASS;    // your network password (use for WPA, or use as key for WEP)
int keyIndex = 0;             // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS;
WiFiServer server(80);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.println("Access Point Web Server");
  // pinMode(LEDR,OUTPUT);
  // pinMode(LEDG,OUTPUT);
  // pinMode(LEDB,OUTPUT);
  // by default the local IP address of will be 192.168.3.1
  // you can override it with the following:
   WiFi.config(IPAddress(192, 168, 1, 21));
  if(strlen(pass) < 8){
    Serial.println("Creating access point failed");
    Serial.println("The Wi-Fi password must be at least 8 characters long");
    // don't continue
    while(true);
  // print the network name (SSID);
  Serial.print("Creating access point named: ");
  Serial.println(ssid);
  //Create the Access point
  status = WiFi.beginAP(ssid,pass);
  if(status != WL_AP_LISTENING){
    // don't continue
    while (true);
  // wait 10 seconds for connection:
  delay(10000);
  // start the web server on port 80
  server.begin();
  // you're connected now, so print out the status
  printWiFiStatus();
 // compare the previous status to the current status
  if (status != WiFi.status()) {
    // it has changed update the variable
    status = WiFi.status();
    if (status == WL_AP_CONNECTED) {
      // a device has connected to the AP
      Serial.println("Device connected to AP");
      // a device has disconnected from the AP, and we are back in listening mode
      Serial.println("Device disconnected from AP");
  WiFiClient client = server.available();   // listen for incoming clients
  if (client) {                             // if you get a client,
    Serial.println("new client");           // print a message out the serial port
    String currentLine = "";                // make a String to hold incoming data from the client
    while (client.connected()) {            // loop while the client's connected
      if (client.available()) {             // if there's bytes to read from the client,
        char c = client.read();             // read a byte, then
        Serial.write(c);                    // print it out the serial monitor
        if (c == '\n') {                    // if the byte is a newline character
          // if the current line is blank, you got two newline characters in a row.
          // that's the end of the client HTTP request, so send a response:
          if (currentLine.length() == 0) {
            // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
            // and a content-type so the client knows what's coming, then a blank line:
            client.println("Content-type:text/html");
            client.println();
            // the content of the HTTP response follows the header:
            client.print("<html><head>");
            client.print("<style>");
            client.print("* { font-family: sans-serif;}");
            client.print("body { padding: 2em; font-size: 2em; text-align: center;}");
            client.print("a { -webkit-appearance: button;-moz-appearance: button;appearance: button;text-decoration: none;color: initial; padding: 25px;} #red{color:red;} #green{color:green;} #blue{color:blue;}");
            client.print("</style></head>");
            client.print("<body><h1> LED CONTROLS </h1>");
            client.print("<h2><span id=\"red\">RED </span> LED </h2>");
            client.print("<a href=\"/Hr\">ON</a> <a href=\"/Lr\">OFF</a>");
            client.print("<h2> <span id=\"green\">GREEN</span> LED </h2>");
            client.print("<a href=\"/Hg\">ON</a> <a href=\"/Lg\">OFF</a>");
            client.print("<h2> <span id=\"blue\">BLUE</span> LED </h2>");
            client.print("<a href=\"/Hb\">ON</a> <a href=\"/Lb\">OFF</a>");
            client.print("</body></html>");
            // The HTTP response ends with another blank line:
            client.println();
            // break out of the while loop:
          } else {      // if you got a newline, then clear currentLine:
            currentLine = "";
        } else if (c != '\r') {    // if you got anything else but a carriage return character,
          currentLine += c;      // add it to the end of the currentLine
        // Check to see if the client request was "GET /H" or "GET /L":
        if (currentLine.endsWith("GET /Hr")) {
          // digitalWrite(LEDR, LOW);               // GET /Hr turns the Red LED on
        if (currentLine.endsWith("GET /Lr")) {
          // digitalWrite(LEDR, HIGH);                // GET /Lr turns the Red LED off
        if (currentLine.endsWith("GET /Hg")){
          // digitalWrite(LEDG, LOW);                // GET /Hg turns the Green LED on
        if (currentLine.endsWith("GET /Lg")){
          // digitalWrite(LEDG, HIGH);                // GET /Hg turns the Green LED on
        if (currentLine.endsWith("GET /Hb")){
          // digitalWrite(LEDB, LOW);                // GET /Hg turns the Green LED on
        if (currentLine.endsWith("GET /Lb")){
          // digitalWrite(LEDB, HIGH);                // GET /Hg turns the Green LED on
    // close the connection:
    client.stop();
    Serial.println("client disconnected");
void printWiFiStatus() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your Wi-Fi shield's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print where to go in a browser:
  Serial.print("To see this page in action, open a browser to http://");
  Serial.println(ip);
Hi @ryuwono,
The issue may be with while (!Serial) { }. This essentially will wait forever until a serial connection is present which is not good practice outside a development environment. As your question is to do with remote monitoring I am assuming you will not have a USB cable attached to the PMC at all times.
Try the following code instead which will wait 5 seconds for a serial connection and then continue the setup if no serial connection is established:
  unsigned long startSetup = millis();
  while (!Serial) {
    if (millis() - startSetup > 5000) { // Time override: 5 seconds
// Continue your code here
Hi @thebeest
For some reason my PMC started bugging out when I uploaded the same code. Serial monitor keeps connecting and disconnecting... would probably need to swap it or return it. I tried this several times, same issue.
may I know if this was resolved. I am trying this myself as well
No luck, unfortunately. I have returned the PMC since then. I think this device was meant to be used with the PLC IDE.
I actually got this working in a few different ways. If there's interest, I can try to put together a sample that worked for me.
@coldie
Wow that's great. Yes that would be great if you could your code as it will be beneficial for everyone here.
I'll clean up my code and share it here. Note that your code is running the wifi as an access point, which is probably what's wrong? (or at least different than my code)
Hi @coldie
I am trying to do something similar and it would be great if you could share your sample code. Thanks.
@coldie can you pls share your sample code
