Simple while loop question
Hello all,
I ran into something I did not understand. I simplified the code for you guys. There are two while loops in which the idea is to send character to the serial monitor for one second. The question is: Why does whileLoopA never end and whileLoopB is working?
unsigned long timeA = 0;
  while (timeA < 1000000) //whileLoopA
   unsigned long timeA = micros();
   Serial.println("A");
  while (micros() < 2000000) //whileLoopB
    Serial.println("B");
  Serial.println("done");
This creates a new, discrete variable. So does NOT updatw the existing variable.
timeA = micros();
is how it should be.
You have assigned timeA twice , in the loop() just have
timeA = micros();
I’m unsure this is the issue , but put a print statement in the loop and see what values you get for timeA to help you debug it .
Note to self : type faster
Ah I see! Thank you for the reply. It does work now! So assigning again does not overwrite the existing timeA.
willybogard:
because the timeA in the while loop is a completely different variable, due to it being in a different scope. If you tried declaring it outside the while loop, you would get a multiple definition error.
