Simple wireless program odd problem.
Alright so i'm trying to send some serial data over wireless (yes not using much error correction right now... just doing a checksum)
i have these two wireless modules
transmitter is connected to 5v power, gnd, and tx pin.
receiver is connected to power, ground, and rx pin on the client. I'm just simply sending a short serial message over a 1200 baud. If i connect the tx -> rx and gnd of the two arduinos it works fine... so the program is running fine. I can't get anything at all over the wireless though.
When i connect an led to gnd and data pin on the reciever it blinks when i send the message on transmistter (so it's getting data.) Here is where i believe my problem is.. When i then leave the LED on the reciever and connect it to the receiver arduino the LED turns on... (so the RX pin on receiver arduino is high? why?)
here is the transmitter and receiver program
trans:
int ledPin = 13;
    Serial.begin(1200);
    Serial.println("setup");
    pinMode(ledPin, OUTPUT);
    digitalWrite(ledPin, HIGH);
    Serial.println("2222");
    digitalWrite(ledPin, LOW);
receiver:
int ledPin = 13;
int inByte = 0;
long blinkTimer = 0;
int blinkInterval = 1000;
    Serial.begin(1200);        // Debugging only
  if (Serial.available() > 0){
    inByte = Serial.read();
    Serial.print(inByte,BYTE);
    if (millis() - blinkTimer>= blinkInterval/2){
      digitalWrite(ledPin,HIGH);
       if (millis() - blinkTimer>= blinkInterval){
      digitalWrite(ledPin,LOW);
      blinkTimer = millis();
ohh man i hope this isn't a special ed question lol
yes the arduino's rx pin is high
hmmm.
In your first post you are showing identical code for reciver and transmitter is that an accident ?
If not - it wont work. The reciever should do some kind of serialRead().
proper code posted.
i would think that rx pin shouldn't be high...
man this is for a college project anyone have any ideas or know how to interface this?
