I am trying to get the simple modbus slave working with the linksprite rs485 converter. I am seeing no TX/RX LEDs on the linksprite shield or on the arduino. For some reason the embedded pin 13 LED is lit. I am using a usb rs485 converter to connect to my PC.
Searching the CPP file I saw no reference to pin 13.
I also am powering the Arduino off of USB. Will this conflict with the TX/RX ports?
I wired the D+/D- to my USB/RS485 converter. Pin 9 is attached to an LED via a resistor to ground. Ground is also attached to RS485 converter. That is all.
I copied source for your reference.
#include <SimpleModbusSlave.h>
/* This example code will receive the adc ch0 value from the arduino master.
It will then use this value to adjust the brightness of the led on pin 9.
The value received from the master will be stored in address 1 in its own
address space namely holdingRegs[].
In addition to this the slaves own adc ch0 value will be stored in
address 0 in its own address space holdingRegs[] for the master to
be read. The master will use this value to alter the brightness of its
own led connected to pin 9.
The modbus_update() method updates the holdingRegs register array and checks
communication.
Note:
The Arduino serial ring buffer is 128 bytes or 64 registers.
Most of the time you will connect the arduino to a master via serial
using a MAX485 or similar.
In a function 3 request the master will attempt to read from your
slave and since 5 bytes is already used for ID, FUNCTION, NO OF BYTES
and two BYTES CRC the master can only request 122 bytes or 61 registers.
In a function 16 request the master will attempt to write to your
slave and since a 9 bytes is already used for ID, FUNCTION, ADDRESS,
NO OF REGISTERS, NO OF BYTES and two BYTES CRC the master can only write
118 bytes or 59 registers.
Using a USB to Serial converter the maximum bytes you can send is
limited to its internal buffer which differs between manufactures.
#define LED 9
// Using the enum instruction allows for an easy method for adding and
// removing registers. Doing it this way saves you #defining the size
// of your slaves register array each time you want to add more registers
// and at a glimpse informs you of your slaves register layout.
//////////////// registers of your slave ///////////////////
enum
// just add or remove registers and your good to go...
// The first register starts at address 0
ADC_VAL,
PWM_VAL,
HOLDING_REGS_SIZE // leave this one
// total number of registers for function 3 and 16 share the same register array
// i.e. the same address space
unsigned int holdingRegs[HOLDING_REGS_SIZE]; // function 3 and 16 register array
/* parameters(HardwareSerial* SerialPort,
long baudrate,
unsigned char byteFormat,
unsigned char ID,
unsigned char transmit enable pin,
unsigned int holding registers size,
unsigned int* holding register array)
/* Valid modbus byte formats are:
SERIAL_8N2: 1 start bit, 8 data bits, 2 stop bits
SERIAL_8E1: 1 start bit, 8 data bits, 1 Even parity bit, 1 stop bit
SERIAL_8O1: 1 start bit, 8 data bits, 1 Odd parity bit, 1 stop bit
You can obviously use SERIAL_8N1 but this does not adhere to the
Modbus specifications. That said, I have tested the SERIAL_8N1 option
on various commercial masters and slaves that were suppose to adhere
to this specification and was always able to communicate... Go figure.
These byte formats are already defined in the Arduino global name space.
modbus_configure(&Serial, 9600, SERIAL_8N2, 2, 2, HOLDING_REGS_SIZE, holdingRegs);
pinMode(LED, OUTPUT);
// modbus_update() is the only method used in loop(). It returns the total error
// count since the slave started. You don't have to use it but it's useful
// for fault finding by the modbus master.
modbus_update();
holdingRegs[ADC_VAL] = analogRead(A0); // update data to be read by the master to adjust the PWM
analogWrite(LED, holdingRegs[PWM_VAL]>>2); // constrain adc value from the arduino master to 255
/* Note:
The use of the enum instruction is not needed. You could set a maximum allowable
size for holdinRegs[] by defining HOLDING_REGS_SIZE using a constant and then access
holdingRegs[] by "Index" addressing.
I.e.
holdingRegs[0] = analogRead(A0);
analogWrite(LED, holdingRegs[1]/4);
#include "SimpleModbusSlave.h"
#include "HardwareSerial.h"
#define BUFFER_SIZE 128
// frame[] is used to recieve and transmit packages.
// The maximum serial ring buffer size is 128
unsigned char frame[BUFFER_SIZE];
unsigned int holdingRegsSize; // size of the register array
unsigned int* regs; // user array address
unsigned char broadcastFlag;
unsigned char slaveID;
unsigned char function;
unsigned char TxEnablePin;
unsigned int errorCount;
unsigned int T1_5; // inter character time out
unsigned int T3_5; // frame delay
HardwareSerial* ModbusPort;
// function definitions
void exceptionResponse(unsigned char exception);
unsigned int calculateCRC(unsigned char bufferSize);
void sendPacket(unsigned char bufferSize);
void modbus_configure(HardwareSerial *SerialPort,
long baud,
unsigned char _slaveID,
unsigned char _TxEnablePin,
unsigned int _holdingRegsSize,
unsigned int* _regs)
ModbusPort = SerialPort;
(*ModbusPort).begin(baud, byteFormat);
slaveID = _slaveID;
holdingRegsSize = _holdingRegsSize;
regs = _regs;
TxEnablePin = _TxEnablePin;
pinMode(TxEnablePin, OUTPUT);
digitalWrite(TxEnablePin, LOW);
errorCount = 0; // initialize errorCount
// Modbus states that a baud rate higher than 19200 must use a fixed 750 us
// for inter character time out and 1.75 ms for a frame delay for baud rates
// below 19200 the timing is more critical and has to be calculated.
// E.g. 9600 baud in a 10 bit packet is 960 characters per second
// In milliseconds this will be 960characters per 1000ms. So for 1 character
// 1000ms/960characters is 1.04167ms per character and finally modbus states
// an inter-character must be 1.5T or 1.5 times longer than a character. Thus
// 1.5T = 1.04167ms * 1.5 = 1.5625ms. A frame delay is 3.5T.
if (baud > 19200)
T1_5 = 750;
T3_5 = 1750;
T1_5 = 15000000/baud; // 1T * 1.5 = T1.5
T3_5 = 35000000/baud; // 1T * 3.5 = T3.5
unsigned int modbus_update()
if ((*ModbusPort).available())
unsigned char buffer = 0;
unsigned char overflow = 0;
while ((*ModbusPort).available())
// The maximum number of bytes is limited to the serial buffer size of 128 bytes
// If more bytes is received than the BUFFER_SIZE the overflow flag will be set and the
// serial buffer will be red untill all the data is cleared from the receive buffer.
if (overflow)
(*ModbusPort).read();
if (buffer == BUFFER_SIZE)
overflow = 1;
frame[buffer] = (*ModbusPort).read();
buffer++;
delayMicroseconds(T1_5); // inter character time out
// If an overflow occurred increment the errorCount
// variable and return to the main sketch without
// responding to the request i.e. force a timeout
if (overflow)
return errorCount++;
// The minimum request packet is 8 bytes for function 3 & 16
if (buffer > 7)
unsigned char id = frame[0];
broadcastFlag = 0;
if (id == 0)
broadcastFlag = 1;
if (id == slaveID || broadcastFlag) // if the recieved ID matches the slaveID or broadcasting id (0), continue
unsigned int crc = ((frame[buffer - 2] << 8) | frame[buffer - 1]); // combine the crc Low & High bytes
if (calculateCRC(buffer - 2) == crc) // if the calculated crc matches the recieved crc continue
function = frame[1];
unsigned int startingAddress = ((frame[2] << 8) | frame[3]); // combine the starting address bytes
unsigned int no_of_registers = ((frame[4] << 8) | frame[5]); // combine the number of register bytes
unsigned int maxData = startingAddress + no_of_registers;
unsigned char index;
unsigned char address;
unsigned int crc16;
// broadcasting is not supported for function 3
if (!broadcastFlag && (function == 3))
if (startingAddress < holdingRegsSize) // check exception 2 ILLEGAL DATA ADDRESS
if (maxData <= holdingRegsSize) // check exception 3 ILLEGAL DATA VALUE
unsigned char noOfBytes = no_of_registers * 2;
// ID, function, noOfBytes, (dataLo + dataHi)*number of registers,
// crcLo, crcHi
unsigned char responseFrameSize = 5 + noOfBytes;
frame[0] = slaveID;
frame[1] = function;
frame[2] = noOfBytes;
address = 3; // PDU starts at the 4th byte
unsigned int temp;
for (index = startingAddress; index < maxData; index++)
temp = regs[index];
frame[address] = temp >> 8; // split the register into 2 bytes
address++;
frame[address] = temp & 0xFF;
address++;
crc16 = calculateCRC(responseFrameSize - 2);
frame[responseFrameSize - 2] = crc16 >> 8; // split crc into 2 bytes
frame[responseFrameSize - 1] = crc16 & 0xFF;
sendPacket(responseFrameSize);
exceptionResponse(3); // exception 3 ILLEGAL DATA VALUE
exceptionResponse(2); // exception 2 ILLEGAL DATA ADDRESS
else if (function == 16)
// Check if the recieved number of bytes matches the calculated bytes
// minus the request bytes.
// id + function + (2 * address bytes) + (2 * no of register bytes) +
// byte count + (2 * CRC bytes) = 9 bytes
if (frame[6] == (buffer - 9))
address = 7; // start at the 8th byte in the frame
regs[index] = ((frame[address] << 8) | frame[address + 1]);
address += 2;
// only the first 6 bytes are used for CRC calculation
crc16 = calculateCRC(6);
frame[6] = crc16 >> 8; // split crc into 2 bytes
frame[7] = crc16 & 0xFF;
// a function 16 response is an echo of the first 6 bytes from
// the request + 2 crc bytes
if (!broadcastFlag) // don't respond if it's a broadcast message
sendPacket(8);
errorCount++; // corrupted packet
exceptionResponse(1); // exception 1 ILLEGAL FUNCTION
else // checksum failed
errorCount++;
} // incorrect id
else if (buffer > 0 && buffer < 8)
return errorCount;
// each call to exceptionResponse() will increment the errorCount
errorCount++;
if (!broadcastFlag) // don't respond if its a broadcast message
frame[0] = slaveID;
frame[1] = (function | 0x80); // set MSB bit high, informs the master of an exception
frame[2] = exception;
unsigned int crc16 = calculateCRC(3); // ID, function|0x80, exception code
frame[3] = crc16 >> 8;
frame[4] = crc16 & 0xFF;
// exception response is always 5 bytes
// ID, function + 0x80, exception code, 2 bytes crc
sendPacket(5);
unsigned int temp, temp2, flag;
temp = 0xFFFF;
for (unsigned char i = 0; i < bufferSize; i++)
temp = temp ^ frame[i];
for (unsigned char j = 1; j <= 8; j++)
flag = temp & 0x0001;
temp >>= 1;
if (flag)
temp ^= 0xA001;
// Reverse byte order.
temp2 = temp >> 8;
temp = (temp << 8) | temp2;
temp &= 0xFFFF;
// the returned value is already swapped
// crcLo byte is first & crcHi byte is last
return temp;
digitalWrite(TxEnablePin, HIGH);
(*ModbusPort).write(frame[i]);
(*ModbusPort).flush();
// allow a frame delay to indicate end of transmission
delayMicroseconds(T3_5);
I just tested this library with 2 arduino uno and 2 shields, one from linksprite, the other from dfrobot. It works fine, you need both the arduino with the rs485 shield on them, and run SimpleModBusSlave on one and SimpleModBusMaster on the other. Is the master that command the slave to change LED luminosity.
