Simpler than an ESC = H-Bridge? No?
I am currently in the process of trying to build an autonomous exploration vehicle based on the Arduino platform. To this end I have been looking for possible motor configurations that would be flexible enough to drive a car both forwards & backwards at various speeds. The best solution I have come across so far however is to use a brushless motor and an ESC circuit, however all the ESCs I have looked at so far seem needlessly complex with endless programmable options (not to mention hard to control using the arduino servo library).
Is there a reason no one seems to uses brushed motors in series with a variable resistor (to change the speed) and h-bridges (to change direction)?
Also, as a side note, can I use any ESC with any brushless motor (provided the recommended max/min current and voltage criteria are fulfilled?)
Yes the reason is that it is a very poor way of controlling the speed of a motor, especially at low speed. The power the resistor dissipates is high and if you want a processor (like the arduino but any processor) to control the motor you can't do it this way as there are no high power digital controlled pots.
No, the method of controlling a brushless motor is different from that of a brushed motor. You need an ESC that is specifically designed to control brushless motors (or can do both types).
The Quick Shield: breakout all 28 pins to quick-connect terminals
