I'm discovering ways to display stuff from my Arduino and the cabling for both the 2 line LCD or - even worse - the 4 digit 7 segment LED seem absolutely crazy, with the latter requiring 10 digital pins or more, plus a bunch of resistors along the way.
Is there no simple 3-cable way to do this (+5v / ground / data) with maybe a chip. If I'm using 10 pins just to display stuff I don't have much left to do anything else
or if you want to go with the 7 segment display you can try the max7219/7221 both do the same thing only the 7221 suport a standard SPI interface and its better for reducing electromagnetic interference and its a bit more expensive
anyway this is well documented on the arduino play ground Arduino Playground - LEDMatrix also the max7219 is very inexpensive if you buy them from ebay, if you do a lil searching youll find 5 max7219 for 1$ + 1$ shipping (dip or smd)
I2C and this article/library is a great choice for controlling a 16x2 LCD. Just two analog pins for the LCD! (I don't know if you can control more than one, though.)
