Simplest sketch doesn't compile
I am using 1.6.4 IDE with a 800 line sketch when it all went horribly wrong with compiler messages spewing out from what was good code. I cut the code down to what you see below and it this still goes wrong. Am I losing my mind...
This is the basic code
ifdef _X_
unsigned char x[2];
endif
unsigned char b()
  return 0;
unsigned char a()
  return b();
void loop(){}
void setup(){}
When the top three lines say
#ifdef _X_
unsigned char x[2];
#endif
The IDE says
does not compile and the IDE messages are:
definetest.ino: In function 'unsigned char a()':
definetest:27: error: 'b' was not declared in this scope
Where as
#ifdef _X_
//unsigned char x[2];
#endif
compiles
And so does
//#ifdef _X_
unsigned char x[2];
//#endif
Changing the order of the functions so b is in the code before a gives
C:\Users\Alan\AppData\Local\Temp\build3893539535880651798.tmp/core.a(main.cpp.o): In function main': D:\Arduino\_Tools\Arduino\arduino-1.6.4\hardware\arduino\avr\cores\arduino/main.cpp:40: undefined reference to setup'
D:\Arduino_Tools\Arduino\arduino-1.6.4\hardware\arduino\avr\cores\arduino/main.cpp:43: undefined reference to `loop'
collect2.exe: error: ld returned 1 exit status
Error compiling.
I am at a loss :frowning:
It's a known unwanted side effect of the way the IDE processes the #include files.
Try adding
char junk;
before the #ifdef
Pete
Use File + Preferences, and enable verbose mode when compiling. Look at the .cpp file that is created from the .ino file. All your questions will be answered.
What the fffffff!
Is that a feature??
When I have these kind of weird errors, usually I add
#include <Arduino.h>
at the top, and it fixes it.
Is that a feature??
It's a matter of the preprocessor team having a lot more people, with a lot more experience at writing parsers, using a lot better tools, than the people developing/maintaining the IDE.
Thanks guys, I'll get back on the job tomorrow now...
