SimpleTimer
I am new to Arduino
I am trying to use the Simpletimer to turn off the button in 5 seconds if it is left on
If I comment out timer.run(); then the est of the program will run but of course not timeout
if I uncomment the line then the program compiles but if I send a ‘d’ it does nothing
What am I missing?
Thank You
Created: 8/31/2016 11:17:18 AM
Author: TAadmin
//Include any library needed
#include <SimpleTimer.h>
// Define default variables
char incomingbyte = ‘a’;
int pushButton = 6;
boolean buttonState = false;
SimpleTimer timer;
// Function to turn of button
void buttonTimeout() {
digitalWrite(pushButton, HIGH);
// the setup function runs once when you press reset or power the board
pinMode(pushButton, OUTPUT);
buttonState = false ;
timer.setInterval(5000, buttonTimeout);
// the loop function runs over and over again until power down or reset
// Read any incoming characters from the USB
incomingbyte = Serial.read();
// Read current button state 0 = off 1 = On
Serial.println(buttonState);
if (incomingbyte == ‘u’){
if (incomingbyte == ‘d’){
digitalWrite(pushButton, LOW);
buttonState = true;
timer.run();
delay(10);
upDate: The button will engage but does not timeout in 5 seconds or ever
timer.run() should be always called. Instead you call it only when "d" is received.
incomingbyte = Serial.read(); You should read only if there is something to read.
https://www.arduino.cc/en/Serial/Read
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
How have you got your button wired, do you have a pull down resistor to pull our input down when your button is open?
Tom.... :slight_smile:
