my program is working but I feel the code could be simplified for cases 2 - 8 as its a bit repetitive. The switch loop runs every 100msec and reptarget = 6 so the web events are issued every 6 seconds with a 0.1 sec delay between each.
So - could I use a single buffer instead of differnent ones (eg static char myDateBuf[ 20 ] ; ?
is there a way to avoid repeating the " if (repCount >= repTarget) {" ?
just looking for a more elegant solution.
switch (state) {
case 0: {
if (!getLocalTime(&timeinfo)) {
Serial.println("Failed to obtain time");
return;
state = 1;
case 1: {
checkPeriod(); //if 6 min elapsed, record current, previous, max values of watts
if (timeinfo.tm_mday != currDay) {
//start of new day
newDay(); //save day data to file
currDay = timeinfo.tm_mday; //update current day
if (timeinfo.tm_mon != currMonth) {
//start of new month
newMonth();
buildDate(); //only needed for web page date & time display
state = 2;
// send web event updates
case 2: {
//Serial.printf("repcount is %i \n", repCount);
events.send("ping", NULL, millis());
state = 3;
case 3: {
static char myDateBuf[ 20 ] ; // make it big enough including trailing /0. Must be static if locally defined.
myDate.toCharArray( myDateBuf, 20 ) ; // myDate is already a String
events.send( myDateBuf , "time", millis());
state = 4;
case 4: {
static char mydTotalkWh[ 12] ;
snprintf(mydTotalkWh, 8, "%7.2f", dTotalkWh); //buffer, max bytes, format specifier (%[flags][width][.precision][length]specifier), value
events.send( mydTotalkWh , "dtotal", millis());
state = 5;
case 5: {
static char myyTotalkWh[ 12] ;
snprintf(myyTotalkWh, 8, "%7.2f", yTotalkWh);
events.send( myyTotalkWh , "ytotal", millis());
state = 6;
case 6: {
static char mypWatts[ 12] ;
snprintf(mypWatts, 8, "%i", pWatts);
events.send( mypWatts , "pwatts", millis());
state = 7;
case 7: {
static char mymWatts[ 12] ;
snprintf(mymWatts, 8, "%i", mWatts);
events.send( mymWatts , "mwatts", millis());
state = 8;
case 8: {
static char mycWatts[ 12] ;
snprintf(mycWatts, 8, "%i", cWatts);
events.send( mycWatts , "cwatts", millis());
repCount = 0; //reset rep count
else repCount++;
state = 9;
case 9: {
state = 0;
} //switch
