Simply two relay timer programmer needed :)
I need some help please programming an arduino nano to
Turn relay (1) on for 1 hour then off for half hour for a period of 48 hours then stop with a led stop indicator coming on on completion.
at the same time
Turn relay (2) on for 2 hours then off for half hour for a period of 24 hours then stop with led stop indicator coming on on completion.
thank you.
i have
relay1 pin 4
relay2 pin 5
led pin 6 (to come on once finished relay1 48hour )
led pin 7 (to come on once finished relay2 24hour )
thank you,
And this will happen only once when you turn the nano on? There's no reset button, no "ok, now it the time to start the sequence" event?
Ok, here you go. Havent tested it, but should do what you said you wanted:
class OnOff {
    const int relayPin;
    const int ledPin;
    const unsigned long onTimeMs;
    const unsigned long offTimeMs;
    const unsigned long totalTimeMs;
    enum State {
      ON, OFF, DONE
    } state;
    unsigned long startMs;
    unsigned long stateMs;
  public:
    OnOff(int relayPin, int ledPin, int onTimeMinutes, int offTimeMinutes, int totalTimeMinutes) :
      relayPin(relayPin),
      ledPin(ledPin),
      onTimeMs(onTimeMinutes * 60L * 1000L),
      offTimeMs(offTimeMinutes * 60L * 1000L),
      totalTimeMs(totalTimeMinutes * 60L * 1000L)
      pinMode(relayPin, OUTPUT);
      pinMode(ledPin, OUTPUT);
      digitalWrite(relayPin, HIGH);
      state = ON;
      stateMs = startMs = millis();
      switch (state) {
        case ON:
          if (millis() - startMs >= totalTimeMs) {
            digitalWrite(relayPin, LOW);
            digitalWrite(ledPin, HIGH);
            state = DONE;
            stateMs = millis();
          else if (millis() - stateMs >= onTimeMs) {
            state = OFF;
            stateMs = millis();
            ; // do nothing
        case OFF:
            state = DONE;
            stateMs = millis();
          else if (millis() - stateMs >= offTimeMs) {
            state = ON;
            stateMs = millis();
            ; // do nothing
        case DONE:
          // do nothing
OnOff relay1(4, 6, 60, 30, 60 * 48);
OnOff relay2(5, 7, 120, 30, 60 * 24);
  relay1.setup();
  relay2.setup();
  relay1.loop();
  relay2.loop();
If you like it, Karma me :)
Hello, I need help with writing one sketch I need to control 2 relays using serial communication.When i turn on one relay they must be on for 15 second. Same things for second relay. However also i need to stop relay at any moment. Thanks P.S. Sorry for my English
What part of that do you need help with? The simplest advice for you to follow is "DO NOT USE DELAY()". The blink without delay example is included with the IDE for a very good reason.
I know that but I still can write right program. I dont know how to use millis(). Can you make it right my sketch.
char junk; String inputString="";
define RELAY_ON 0
define RELAY_OFF 1
void setup() { Serial.begin(9600); digitalWrite(4, RELAY_OFF); digitalWrite(5, RELAY_OFF); pinMode(4, OUTPUT); pinMode(5, OUTPUT);
void loop() { if(Serial.available()){ while(Serial.available()) { char inChar = (char)Serial.read(); inputString += inChar; } while (Serial.available() > 0) { junk = Serial.read() ; } if(inputString == "a"){ digitalWrite(4, HIGH); Serial.println("STOP RELAY 1"); }else if(inputString == "A"){ Serial.println("START RELAY 1"); digitalWrite(4, LOW); delay(15000); digitalWrite(4,HIGH); }else if(inputString == "b"){ Serial.println("STOP RELAY 2"); digitalWrite(5, HIGH); }else if(inputString == "B"){ Serial.println("START RELAY 1"); digitalWrite(5, LOW); delay(15000); digitalWrite(5,HIGH);
} inputString = ""; } }
AldinT:
Well, there’s your problem right there.
PaulMurrayCbr: Well, there's your problem right there.
Thanks anyway
How would YOU make the two relays operate and still be able to read the switch? You have a watch, a pencil and some paper.
THINK about the steps you would need to perform if I called you on the phone and said to turn the oven and coffeemaker on for 15 minutes unless the fire alarm goes off.
What are the first things that you would do?
(Forget about the Arduino and how to write the code to make it do something. Until you know what it is to do, you can't write the code. Once you know what it is to do, the code is just about done. All that is left is getting the syntax correct.)
