Simulate a welding arc light
I'm a newbie. how do I blink the two leds at varying rates each separately. I can setup one led to blink on and off using delay but how do I do the same with 2 leds. I would like to have at least 10 high and 10 low with 10 different values of time for each one of the 10 high and ten low. 10 high and 10 low for each led. This one i found just blinks each led at different rates is there a way to accomplish my goal with this sketch?
/* Blink Multiple LEDs without Delay * * Turns on and off several light emitting diode(LED) connected to a digital * pin, without using the delay() function. This means that other code * can run at the same time without being interrupted by the LED code. */ int led1 = 3; // LED connected to digital pin 13 int led2 = 5; int value1 = LOW; // previous value of the LED int value2 = LOW; // previous value of the LED long time1 = millis(); long time2 = millis();
long interval1 = 45; // interval at which to blink (milliseconds) long interval2 = 33;
void setup() { pinMode(led1, OUTPUT); // sets the digital pin as output pinMode(led2, OUTPUT); }
void loop() { unsigned long m = millis();
if (m - time1 > interval1){ time1 = m;
if (value1 == LOW) value1 = HIGH; else value1 = LOW;
digitalWrite(led1, value1); }
if (m - time2 > interval2){ time2 = m;
if (value2 == LOW) value2 = HIGH; else value2 = LOW;
digitalWrite(led2, value2); } } any help would be greatly be appreciated THanks
How about using random (min, max) to define the time intervals they are off and on? Each time an LED completes one cycle, randomize its next turn on time.
Repeat your code for 10 LEDs, or set it up as a loop and a couple of arrays to hold the on/off states and the randomized on/off times.
