Simulated minefield using pressure sensors
And here's where I embarrass myself by asking how to actually do that "parallel wiring w/ 10k resistor" config with Arduino - connect them up to a breadboard? (I'm really new to this stuff.)
Also, practically speaking, that means much more wire on the floor... is wiring in series that much more difficult? If I create a 5 x 8 grid and connect each pressure sensor (two wires attached to aluminum foil separated by velostat) along the path using the wires, will that work? What issues will I have?
Thanks again for all the help!
Pete
