Simulated Temperature Control
I currently have code written that increments and decrements a counter printed on an arduino 16x2 LCD display. I currently have one 3 prong SPDT swtich wired each to an input and the center pin grounded. When one side is triggered low(using pullup) it increases that temperature when the other side is low it decreases the temperature. I want to add in another digital switch, the function would be when this new switch is either high allow me to adjust the temperature. I need to be displaying the current temperature when the switch is low, and the new switch will be adjusting the set point not changing the current temperature. Please help.
#include <LiquidCrystal.h>
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
const byte  up1 = 5;    // the pin that the Up pushbutton is attached to
const byte  down1 = 6;    // the pin that the Down pushbutton is attached to
// Variables will change:
byte buttonPushCounter = 0;   // counter for the number of button presses
byte buttonState5;         // current state of the button
byte buttonState6;         // current state of the button
byte lastButtonState = 0;     // previous state of the button
  pinMode(up1, INPUT_PULLUP);
  pinMode(down1, INPUT_PULLUP);
  lcd.begin(16, 2);
  lcd.setCursor(7, 1);
  lcd.print(0);
  // read the pushbutton up input pin:
  buttonState5 = digitalRead(up1);
  // compare the buttonState to its previous state
  if (buttonState5 != lastButtonState) {
    // if the state has changed, increment the counter
    if (buttonState5 == LOW)
      buttonPushCounter++;
      lcd.print(buttonPushCounter);
    delay(50);
  // save the current state as the last state,
  //for next time through the loop
  lastButtonState = buttonState5;
  // read the pushbutton down input pin:
  buttonState6 = digitalRead(down1);
  if (buttonState6 != lastButtonState) {
    // if the state has changed, decrement the counter
    if (buttonState6 == LOW)
      buttonPushCounter--;
    delay(50);
  lastButtonState = buttonState6;
First of all you need a separate lastButtonState variable for each button.
You also may want to debounce each contact properly, see the sample projects.
I have separated the button states. For the debouncing I used the debounce sample.
  const byte  up1 = 8;    // the pin that the Up pushbutton is attached to
  const byte  down1 = 9;    // the pin that the Down pushbutton is attached to
  byte lastButtonState1 = 0;     // previous state of the button
  byte lastButtonState2 = 0;
    lcd.begin(16, 2);
    lcd.print(0);
    if (buttonState5 != lastButtonState1) {
      delay(50);
    lastButtonState2 = buttonState5;
    if (buttonState6 != lastButtonState2) {
      delay(50);
    lastButtonState2 = buttonState6;
I'd suggest that you use an array of button states, to eliminate coding errors in the variable names. Like this
newState = digitalRead(buttonPin*);*
_ if (newState != buttonState*) {_
_
..._
_ buttonState = newState;
}*_
