Simulating sensor?
Hi guys, I want to know it is possible to simulate a sensor with array? for example reading the voltage sensor analog output values and save the output integers in a array.
thanks.
analogRead() returns a sensor value from 0 to 1023, so you can simulate this by plugging in an integer starting at 0 and incrementing to 1023 to test the entire range.
thanks for your response. So it is possible ! I want to read the sine wave period with an analog sensor ( simulated ) and compare its value with a real sensor. Do you think it is possible?
As long as the sign wave is in the range between 0 VDC and analogReference(), set to 5 volts by default on the Arduino Uno, it's entirely doable.
Thank you for taking the time to respond to me.
Yes, it sounds like you want to do several things at the same time one of them simulating a sensor, and others being the rest of your code.
Here's some code in Wokwi simulating some analog voltages: QuickChargeControl.ino - Wokwi Arduino and ESP32 Simulator
