Simulation SDI-12
Hi everybody.
I want to simulate SDI-12, but it seems that the SDI-12 library does not work with Proteus. Can you tell me whether it can work or not?
//MASTER CODE
#include <SDI12.h>
#define SERIAL_BAUD 9600 /*!< The baud rate for the output serial port */
#define DATA_PIN 2        /*!< The pin of the SDI-12 data bus */
#define POWER_PIN 3       /*!< The sensor power pin (or -1 if not switching power) */
String inputString = "";         // a String to hold incoming data
bool stringComplete = false;  // whether the string is complete
SDI12 mySDI12(DATA_PIN);
char   inByte      = 0;
String sdiResponse = "";
String myCommand   = "";
  // initialize serial:
  pinMode(13, OUTPUT);
  inputString.reserve(200);
  mySDI12.begin();
  delay(500);  // allow things to settle
  // Power the sensors;
  if (POWER_PIN > 0) {
    Serial.println("Powering up sensors...");
    pinMode(POWER_PIN, OUTPUT);
    digitalWrite(POWER_PIN, HIGH);
    delay(200);
  serialEvent1();
  if (stringComplete) {
    if(inputString =="?!\n")
       digitalWrite(13, HIGH);
       Serial.println('1');  //Send Address
      if(inputString =="0D0!\n")
       digitalWrite(13, LOW);
       Serial.println("113EP100G-08 01151108151545");  //request probe ID
    Serial.println(inputString);
    // clear the string:
    inputString = "";
void serialEvent1() {
  while (mySDI12.available()) {
    char inChar = (char)mySDI12.read();
    // add it to the inputString:
    inputString += inChar;
    // if the incoming character is a newline, set a flag so the main loop can
    // do something about it:
    if (inChar == '\n') {
      stringComplete = true;
//SLAVE CODE
#include <SDI12.h>
/** Define the SDI-12 bus */
  mySDI12.begin();
 //   Serial.println("Powering up sensors...");
    delay(200);
   mySDI12.sendCommand("?!");
   mySDI12.sendCommand("0D0!");
Is your question if your setup/code will work in real life or how to get it working in proteus? For proteus related questions, you're probably better of on a proteus forum.
You don't seem to have a problem with the IDE hence your topic has been moved.
