So I am getting ready for my first Arduino to arrive on Thursday or Friday and I would like to have my schematics perfect, along with any extra parts needed.
Duemilanove - 14 I/O Ports
I have 7 I/O ports that are forced to be there, so there is no way I can minimize these slots.
I would also like to use 14 transistor-controlled buttons, which easily puts me over my I/O port limit.
Right now I have (4) 2-to-4 decoders that will control these buttons, but no matter how I group the buttons I will somehow manage to press two of them at one time. Pressing two at one time is not possible with the decoders unless I add a timing circuit, to force the button to stay on for a second, to each button which I am not happy with unless it is the only option.
I read about using a shift register to control extra I/O pins. This would work, but I do believe I would be getting random button presses since each bit has to actually shift through the register. So really this would not work, unless this is operating in a way different than I believe.
I also read about I2C x-bit I/O port expanders. These seem to work, but is it possible to control each port at different times?
Thanks for the long-winded post here, but I would love to find an answer to this problem.
No, there is a latch on the shift register outputs nothing changes until the latch is triggered.
Yes.
It is not clear if you are talking about inputs or outputs in this post. A button is an input but then you talk of controlling the buttons. You read inputs, you control outputs.
On the other hand avoid using pins 0 and 1 as these are used for the serial communications, like uploading the programs. You can use them but it is not a beginners thing.
OK that is not called controlling a button, that is more like simulating a button press on an other piece of equipment.
