Simultaneous servo and esc control with NRF24l01 over two servos
Hello, I am currently working on a project that requires me to communicate two analog signals from a joystick (X and Y) that control either an electronic speed controller or a servo. I have done this successfully over a wired connection on a single board, with the code shown below:
// Hardwired Hovercraft Program Version
#include <Servo.h>
Servo ESC; // creates servo object to control the ESC
Servo servo; // creates servo object to control servo
int JoysX;  // value from the analog pin 0
int JoysY;  // value from the analog pin 1
  // Attach the ESC on pin 9
  ESC.attach(6,1000,2000); // (pin, min pulse width, max pulse width in microseconds to arm ESC)
  servo.attach(5);
  JoysX = analogRead(A0);   // reads the value of the potentiometer (value between 0 and 1023)
  JoysX = map(JoysX, 0, 1023, 0, 180);   // scales it to use it with the servo library (value between 0 and 180)
  ESC.write(JoysX);    // Sends the signal to the ESC
  JoysY = analogRead(A1);   // reads the value of the potentiometer (value between 0 and 1023)
  JoysY = map(JoysY, 0, 1023, 0, 180);   // scales it to use it with the servo library (value between 0 and 180)
  servo.write(JoysY);    // Sends the signal to the Servo
Although this works, what I am attempting to complete is to have two Arduino boards, one a transmitter, and one a receiver, over two nrf24l01 modules, where the transmitter can communicate two analog signals at once to the receiver. I have attempted to program this myself, although it is proving quite difficult. The code for both the transmitter and receiver is shown below:
TX CODE:
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
RF24 radio(7, 8); // CE, CSN
const byte address[6] = "00001";
  radio.begin();
  radio.openWritingPipe(address); // 00001
  radio.setPALevel(RF24_PA_MIN);
  radio.stopListening();
  int JoysValueX = analogRead(A0);
  int angleValueX = map(JoysValueX, 0, 1023, 0, 180);
  radio.write(&angleValueX, sizeof(angleValueX));
  int JoysValueY = analogRead(A1);
  int angleValueY = map(JoysValueY, 0, 1023, 0, 180);
  radio.write(&angleValueY, sizeof(angleValueY));
RX CODE:
#include <SPI.h>
#include <RF24.h>
#include <Servo.h>
Servo SteeringSystem;
Servo ESC;
  SteeringSystem.attach(5);
  ESC.attach(6);
  radio.begin();
  radio.openReadingPipe(1, address); // 00001
  delay(5);
  radio.startListening();
  if ( radio.available()) {
    while (radio.available()) {
      int angleVX = 0;
      int angleVY = 0;
      radio.read(&angleVX, sizeof(angleVX));
      SteeringSystem.write(angleVX);
      radio.read(&angleVY, sizeof(angleVY));
      ESC.write(angleVY);
I don't know if communicating two analog signals at once through an nrf24l01 module is possible or plausible, so if anyone can help me out, it would be much appreciated.
This might be of use. It's the repository for a combat robot I built.
https://github.com/IceChes/Flash_Memory
Put your two values into a "struct" and transmit the struct.
Project #2 of the following has an example where the struct contains two ints (could be your two analogReads), a float, and a char message. The transmitter sends that entire package to the receiver...
Arrays also work but structs are more intuitive.
Here is example code that sends 2 LDRs (LIght Dependent Resistor) data in a struct and receives the struct to display the LDR values. The code uses some methods from the Robin2's simple rf24 tutorial.
sender:
#include <SPI.h>
#include <RF24.h>
const byte CE_PIN = 9;
const byte CSN_PIN = 10;
const byte slaveAddress[5] = {'R', 'x', 'A', 'A', 'A'};
RF24 radio(CE_PIN, CSN_PIN); // Create a Radio
struct LdrValues
  int ldr_1;
  int ldr_2;
}ldrValues;
unsigned long currentMillis;
unsigned long prevMillis;
unsigned long txIntervalMillis = 1000; // send once per second
const byte LDR1 = A0;
const byte LDR2 = A1;
   Serial.println("SimpleTx Starting");
   pinMode(LDR1, INPUT_PULLUP);
   pinMode(LDR2, INPUT_PULLUP);
   radio.begin();
   radio.setChannel(76);  //76 library default
   //RF24_PA_MIN, RF24_PA_LOW, RF24_PA_HIGH and RF24_PA_MAX
   radio.setPALevel(RF24_PA_HIGH);
   radio.setDataRate( RF24_250KBPS );
   radio.setRetries(3, 5); // delay, count
   radio.openWritingPipe(slaveAddress);
   currentMillis = millis();
   if (currentMillis - prevMillis >= txIntervalMillis)
      send();
      Serial.print("LDR 1 = ");
      Serial.print(ldrValues.ldr_1);
      Serial.print("    LDR 2 = ");
      Serial.println(ldrValues.ldr_2);
      prevMillis = millis();
void send()
   ldrValues.ldr_1 = analogRead(LDR1);
   ldrValues.ldr_2 = analogRead(LDR2);
   radio.write( &ldrValues, sizeof(ldrValues) );
receiver
// SimpleRx - the slave or the receiver
#include <SPI.h>
#include <RF24.h>
const byte thisSlaveAddress[5] = {'R', 'x', 'A', 'A', 'A'};
struct LdrValues
   int ldr_1;
   int ldr_2;
} ldrValues;
bool newData = false;
   Serial.println("SimpleRx Starting");
   radio.begin();
   radio.openReadingPipe(1, thisSlaveAddress);
   getData();
   showData();
void getData()
   if ( radio.available() )
      radio.read( &ldrValues, sizeof(ldrValues) );
      newData = true;
void showData()
   if (newData == true)
      Serial.print("Data received >> ");
      newData = false;
After the reapplication of this code, the ESC on pin 6 does arm after I send the '0' value from the X axis potentiometer, however, I cannot control either one of the Servo objects, and the ESC is stuck on its maximum setting. I didn't use pin A2 for analog, so I felt as though I didn't need it, but I need to understand why it is there, so I can see whether or not to put it to use. The code used is shown below:
Transmitter:
//Inspired largely by IceChes
#include <SPI.h>
#include <RF24.h>
int num[1]; //Configure packet to send
int X;
int Y;
RF24 radio(9, 10); // CE, CSN of RF
const byte address[6] = "00001"; //Channel one
  radio.begin();
  radio.setPALevel(RF24_PA_MAX); //All of the power
  X = analogRead(A0);
  Y = analogRead(A1);
  num[0] = X;
  num[1] = Y;
  radio.write(&num, sizeof(num)); //SEND IT
Reciever:
#include <SPI.h>
#include <RF24.h>
#include <Servo.h>
RF24 radio(9, 10); // CE, CSN of the RF
Servo ESC; //Attach ESC as a servo
Servo SteeringSystem; //Attach Steering System as a servo
int num[32];
const byte address[6] = "00001"; //Channel 1
int ESCWrite;
int SSWrite;
int potRead;
int xDir = 90;       // inital direction for esc later
int yDir = 90;      // initial direction for servo later
  ESC.attach(6, 1000, 2000); //Timings for ESC
  radio.begin();
  radio.openReadingPipe(0, address);
  radio.setPALevel(RF24_PA_MAX); //Amplify it
  if (radio.available()) {
    radio.read(&num, sizeof(num)); //Get packet and assign values
    Serial.println(num[0]);
    Serial.println(num[1]);
    ESCWrite = map(num[0], 0, 1024, 0, 180); //Map ESC to full power
    ESC.write(ESCWrite);
    SSWrite = map(num[1], 0, 1024, 0, 180); //Map Servo to full power
    SteeringSystem.write(SSWrite);
    XRead();
    YRead();
void XRead() {
  if (num[0] > 600) {             // if data is greater than 600
  xDir = 0;                       // dir is 0
  ESC.write(xDir);             // TURN
  else if (num[0] < 400) {         // more if data for x axis, (steering)
  xDir = 90;                       // 90 is straight
  ESC.write(xDir);               // no turn
  else {                          // if data 0 is equal to 0. servo turns left
  xDir = 180;                    // see unit circle
void YRead() {
  if (num[1] > 600) {             // if data is greater than 600
  yDir = 0;                       // dir is 0
  SteeringSystem.write(yDir);             // TURN
  else if (num[1] < 400) {         // more if data for x axis, (steering)
  yDir = 90;                       // 90 is straight
  SteeringSystem.write(yDir);               // no turn
  yDir = 180;                    // see unit circle
num[1] is an array with only 1element. You are trying to use 2 (num[0] and num[1]).
Steve
So you are sending data. Great!
Arrays are kind of weird, and there's one small problem. Spot the difference.
Transmitter:
#include <SPI.h>
#include <RF24.h>
int num[2]; //Configure packet to send
int X;
int Y;
  radio.begin();
  X = analogRead(A0);
  Y = analogRead(A1);
  num[0] = X;
  num[1] = Y;
Receiver:
#include <SPI.h>
#include <RF24.h>
#include <Servo.h>
int num[32];
int ESCWrite;
int SSWrite;
int potRead;
  radio.begin();
    XRead();
    YRead();
void XRead() {
void YRead() {
EDIT - Disclaimer: This may not fix 100% of your problems. Without being able to test, I don't know.
It works! After using the change given, it had still not been communicating with the other, but a simple switch for the nRF24l01+pa+lna module (The more powerful one with the antenna) from 3.3v to 5v made it work smoothly. It is almost instant feedback, and I could not be happier. Thanks for your help!
