Hello, Arduino Ethernet Shield supports up to four simultaneous socket connections.
1) Does it means I can connect with my arduino using TCP and UDP protocols simultaneously onto one port on a PC and both connections stays oppened simultaneously? 2) Will it be then possible in one loop to send messages TCP and UDP as I choose without reopenning the connection?
Does anyone has the experiance with this? Petr
