Is there a problem with trying to use the Ethernet and Wire libraries at the same time?
I have a sketch that waits for an incoming UDP message which contains a command. In response to the command my Uno needs to communicate to a Smart Battery using the I2C bus. The data obtained from the Smart Battery is then packaged up into a UDP message and the message is sent back to the client via Ethernet. When the Sketch is run, I can see the incoming UDP message is decoded properly, but the call to Wire.write just hangs.
Note that I have another Sketch that does NOT use the Shield and uses the Wire library to talk to a Smart Battery with no issue (similar Wire lib code).
I use the Ethernet shield and I2C together no problems. Post your code.
Here is a stripped-down version of the code that exhibits the problem.
See function sendCmd. The calls to Wire.beginTransmission, Wire.write return OK. The call to Wire.endTransmission never returns.
// 1 2 3 4 5 6 7 8
//345678901234567890123456789012345678901234567890123456789012345678901234567890
SmartBatMon.ino
1. Wait for UDP message from client
2. Parse command
3. Create message containing response to command
4. Send UDP message back to client
Incoming Message syntax:
"?Static"
Outgoing (returned) Message syntax:
In response to ?Static command:
"S," followed by a comma separated list of text values that I determined
need to be read 1 time. In this Sketch, only the Smart Battery's
manufacturer and device name are queried.
#include <SPI.h> // needed for Arduino versions later than 0018
#include <Ethernet.h>
#include <EthernetUdp.h> // UDP library from: bjoern@cs.stanford.edu 12/30/2008
#include <Wire.h>
const int batAddr = 0x0B; // Smart Battery slave address
byte mac[] = {0x90, 0xA2, 0xDA, 0x0D, 0x9B, 0x4A}; // MAC address of Arduino
unsigned int localPort = 8888; // local port to listen on
// Room for entire contents of static or dynamic message response
const unsigned int ReplyBufferSize = 256; // Size of reply buffer
// ****** Smart Battery Commands & Returned Data Type ******
const byte cmdManufName = 0x20; // string, Manufacturer's name
const byte cmdDevName = 0x21; // string, Device name
const byte cmdDevChem = 0x22; // string, Device chemistry
// buffers for receiving amd sending data
char cPacketBuffer[UDP_TX_PACKET_MAX_SIZE]; //buffer to hold incoming packet
char cReplyBuffer[ReplyBufferSize];
// An EthernetUDP instance to let us send and receive packets over UDP
EthernetUDP Udp;
// Debug mode
boolean debug;
// Simulation mode (1 = On (no battery connected), 0 = Off (battery connected)
int simMode;
// start the Ethernet and UDP:
Ethernet.begin(mac); // Using DHCP
Udp.begin(localPort);
Serial.println("SmartBatMon sketch executing...");
debug = false;
// Set simMode Off (battery connected)
// Set simMode = 1 to just return canned buffer when no battery is connected.
simMode = 0;
const char comma = ',';
String strTempString = "";
// if there's data available, read a packet
int packetSize = Udp.parsePacket();
if (packetSize)
Serial.print("Received ");
Serial.print(packetSize);
Serial.print(" byte packet from ");
IPAddress remote = Udp.remoteIP();
for (int i =0; i < 4; i++)
Serial.print(remote[i], DEC);
if (i < 3)
Serial.print('.');
Serial.print(", port ");
Serial.println(Udp.remotePort());
// read the packet into cPacketBufffer
Udp.read(cPacketBuffer, UDP_TX_PACKET_MAX_SIZE);
cPacketBuffer[packetSize] = 0; // Null-terminate the buffer
Serial.print("Contents: ");
Serial.print('"');
Serial.print(cPacketBuffer);
Serial.println('"');
// Parse the command
String Spb = String(cPacketBuffer);
// Convert to upper case
Spb.toUpperCase();
if (Spb.substring(0,7) == "?STATIC") // ENDING index NOT included!
getStatic();
sprintf(cReplyBuffer, "ERROR: Unknown command!");
sendReply();
Serial.println("----------------------------------------");
delay(10);
// function sendCmd()
// Purpose:
// Sends a command to Smart Battery. Checks for transmission error.
// Parameters:
// byte cmd: SB spec command value
// Returns:
// unsigned int: Transmission error code
unsigned int sendCmd(byte cmd)
byte errorCode = 0;
Serial.println("Call Wire.beginTransmission"); // See this
Wire.beginTransmission(batAddr);
Serial.println("Call Wire.write"); // See this
Wire.write(cmd);
Serial.println("Call Wire.endTransmission"); // See this
errorCode = Wire.endTransmission();
Serial.println("Ret from Wire.endTransmission"); // NEVER see this
if (errorCode)
Serial.print("Wire.write returned errorCode 0x");
Serial.println(errorCode, HEX);
return(errorCode);
// function readDataWord()
// Purpose:
// Reads a 16-bit integer from the Smart Battey
// Parameters:
// None
// Returns:
// int: 16-bit value returned in response to command
int readDataWord()
byte data1, data2;
int retWord;
Wire.requestFrom(batAddr, 2);
data1 = Wire.read();
data2 = Wire.read();
retWord = (256 * data2) + data1;
if (debug)
Serial.print("Returned word = 0x");
Serial.println(retWord, HEX);
return(retWord);
// function readDataString()
// Purpose:
// Reads a character string from Smart Battery
// Parameters:
// None
// Returns:
// String: character string returned in response to command
String readDataString()
// From the Smart Battery spec:
// When a command returns "string", the first byte is a count (up to 32) of
// the characters that follow.
String dataString = "";
Wire.requestFrom(batAddr, 15);
// Get the number of characters in the returned string
int blkCnt = Wire.read();
while (blkCnt > 0)
dataString += (char)Wire.read();
blkCnt--;
return(dataString);
// function sendReply()
void sendReply()
// send reply to IP address and port that sent us the packet we received
//Serial.println(Udp.remotePort());
Serial.println("Reply Buffer:");
Serial.println(cReplyBuffer);
delay(100);
// NOTE: Port number used here MUST match recvPort in VB code!
Udp.beginPacket(Udp.remoteIP(), 9898);
Udp.write(cReplyBuffer);
Udp.endPacket();
// function sendCmdGetResponse()
// Parameters:
// byte cmdCode: Command to send
// Returns: Response to command or "ERROR"
String sendCmdGetResponse(byte cmdCode)
String strReturnData = "ERROR";
unsigned sendStatus = sendCmd(cmdCode);
if (sendStatus == 0)
if ((cmdCode >= cmdManufName) && (cmdCode <= cmdDevChem))
strReturnData = readDataString();
strReturnData = String(readDataWord());
return(strReturnData);
// function getStatic()
void getStatic()
String strStaticBuff = "";
// Returns the following information. Each item is comma separated string.
// 1. Manufacturer name
// 2. Device name
// Indicate static data being returned
strStaticBuff = "S";
strStaticBuff += comma;
// *********************** Manufacturer name ***********************
if (simMode == 0)
strStaticBuff += sendCmdGetResponse(cmdManufName);
strStaticBuff += "Panasonic";
// *********************** Device name ***********************
if (simMode == 0)
strStaticBuff += sendCmdGetResponse(cmdDevName);
strStaticBuff += "MyBat";
// Convert String to char and send it to client
strStaticBuff.toCharArray(cReplyBuffer, ReplyBufferSize);
sendReply();
Where is your Wire.begin() call in setup?
Oh crap! Chalk this up a to a copy/paste error. Sketch seems to be working fine now.
Thank you, Surfer Tim, for taking the time to help!
However, you would think the very FIRST call to the Wire library would be the one to hang, not the 3rd one.
