Sine Current Source Inverter
I've seen sine voltage source inverter (VSI) using arduino. Is there anyone now how to use arduino to make Sine Current Source Inverter (CSI)?
Use the inverse of a transimpedance amplifier: voltage controlled current source.
Can it take pwm signal?
What is the application, your project?
Thanks.. Tom... :smiley: :+1: :coffee: :australia:
I want to make waveform generator but for current.
Using a voltage waveform to draw current is an easy task using a MOSFET but, why are you wanting to do this? Do you want to make a AC power supply that runs from batteries?
Voltage controlled current source:
Going to be tricky if he wants AC current! :roll_eyes:
It might be useful to know the project in a bit more detail as there may be other solutions
