Sine to rectangular
val1[i] is changing from 0 to 80, why : if (val1[i] >> 40) is not working, on PC13 I have 1.65V ?
//1.65V
#define SAMPLES 77
#include <libmaple/dma.h>
dma_tube_config dma_cfg, dma_cfg2;
int flag1 = 0;
int out1 = PB7;
int val1[SAMPLES];
int16 shift = 0;
int amp = 40;
int cnt = 0;
int time_track = 0;
float stp = 6.2831 / SAMPLES;
int ret = 17;
timer_dev *dev1 = PIN_MAP[out1].timer_device;
uint8 cc_channel1 = PIN_MAP[out1].timer_channel;
void fun1()
  flag1++;
void timer_conf()
  timer_dma_set_base_addr(dev1, TIMER_DMA_BASE_CCR2);
  timer_dma_set_burst_len(dev1, 1);
  timer_dma_enable_req(dev1, cc_channel1);
  timer_set_reload(dev1, 102);
  timer_set_prescaler(dev1, 0);
void dma_conf()
  dma_init(DMA1);
  /* T4C2 DMA C4 */
  dma_cfg.tube_dst = &(dev1->regs.gen->DMAR);
  dma_cfg.tube_dst_size = DMA_SIZE_32BITS;
  dma_cfg.tube_src = val1;
  dma_cfg.tube_src_size = DMA_SIZE_32BITS;
  dma_cfg.tube_nr_xfers = SAMPLES;
  dma_cfg.tube_flags = DMA_CFG_SRC_INC | DMA_CFG_CIRC | DMA_CFG_CMPLT_IE;
  dma_cfg.tube_req_src = DMA_REQ_SRC_TIM4_CH1;
  dma_cfg.tube_req_src = DMA_REQ_SRC_TIM4_CH2;
  dma_cfg.target_data = 0;
  ret = dma_tube_cfg(DMA1, DMA_CH4, &dma_cfg);
void dma_start()
  dma_enable(DMA1, DMA_CH4);
  timer_resume(dev1);
  dma_enable(DMA1, DMA_CH1);
  dma_enable(DMA1, DMA_CH2);
void init_wave()
  int i;
  for (i = 0; i < SAMPLES; i++)
    val1[i] = 40 + amp * sin(stp * i);// = 0/80
  pinMode(out1, PWM);
  timer_conf();
  dma_conf();
  dma_start();
  init_wave();
  int i;
   if  (val1[i] >> 40)
   digitalWrite (PC13, HIGH);
   digitalWrite (PC13, LOW);
>> is the bitshift operator. Is that the intention?
Or do you want to check if the value is greater than 40?
> greater than
>= greater than or equal to
1.65v sounds like 3.3 volts with a 50% duty cycle.
But, since variable [i] is always zero in loop(), that’s not the problem... or is it?
  int i;
   if  (val1[i] >> 40)
..and the value of i is . . . what?
(And the thing about the shift operator)
I fixed that = still nothing on PC13
, Thanks
We can't see your fixed code.
I forgot pin mode = PC13 = 0.05V sawtooth
pinMode(out2, OUTPUT);
It is not fixed because I don't have rectangles,
here is updated
//1.65V
#define SAMPLES 77
int flag1 = 0;
int out1 = PB7;
int out2 = PC13;
int val1[SAMPLES];
int16 shift = 0;
int amp = 40;
int cnt = 0;
int time_track = 0;
int ret = 17;
void fun1()
  flag1++;
void timer_conf()
void dma_conf()
  dma_init(DMA1);
  /* T4C2 DMA C4 */
void dma_start()
  timer_resume(dev1);
void init_wave()
  int i;
  pinMode(out1, PWM);
  timer_conf();
  dma_conf();
  dma_start();
  init_wave();
  int i;
   if  (val1[i] > 40)
See reply #5
0 to 4096
Wrong.
Have another guess.
Hint: it should be in the range 0 to 76 inclusive.
But is it?
regardless i , sin is varying between -1 and +1
sin(stp * i)
amp = 40
val1[i] = 40 - 40 = 0 = min val
val1[i] = 40 +40 = 80 = max val
I asked a very specific question about the value of the variable "i" within the function "loop()".
I agree with that
But what is it?
Why this is important, sin(i) can't be higher than 1 and lower than -1
It's important because an uninitialised variable used as an array index could point ANYWHERE in memory.
(And yes, C/C++ allows negative array indices)
I added this and on LCD i = 0
int i;
  lcd.setCursor(0, 0);
  lcd.print("i = ");
  lcd.print(i);
Congratulations! You got lucky.
Don't rely on it.
I know that, I did that for curiosity
