sine wave generator can't make a time shifting smooth one
Hello.
Now I’m going to make a sine wave generator which generates time shifting wave like a spring.
I have built a source code like the below but its performance is not smooth.
I need your help.
/*for loop で一応の目的を達成した*/
#include "Waveforms.h"
#define onefrequencySample 1000000/maxSamplesNum  // sample for the 1frequency signal expressed in microseconds
unsigned long startMillis;
unsigned long currentMillis;
const unsigned long period = 200;
volatile int wave1 = 0;
int i = 0;
int j = 0;
int sample;
double frequency=50.0;
double displacement=3;
/*millis for loop でプログラム作成成功*/
  analogWriteResolution(12);  // set the analog output resolution to 12 bit (4096 levels)
  currentMillis = millis();
  for(int j=0; j<=21; j++)
    if( (currentMillis - startMillis <= period * j ) &&(j <= 10))
     sample = map(frequency - displacement *j, 0, 4095, 0, onefrequencySample);
     sample = constrain(sample, 0, onefrequencySample);
      analogWrite(DAC1, waveformsTable[wave1][i]);  // write the selected waveform on DAC1
      i++;
      if(i == maxSamplesNum)  // Reset the counter to repeat the wave
     i = 0;
     delayMicroseconds(sample);  // Hold the sample value for the sample time
     else   if (( currentMillis - startMillis <= period *j) &&(j > 10)&&(j<21))
     sample = map(frequency - displacement *(20-j), 0, 4095, 0, onefrequencySample);
      i++;
     i = 0;
  for(int j=10; j<20; j++)
    if (currentMillis - startMillis <= period * j)
     sample = map(frequency - displacement *(10-j), 0, 4095, 0, onefrequencySample);
      i++;
     i = 0;
//      delayMicroseconds(sample);  // Hold the sample value for the sample time
    if (currentMillis - startMillis == period * 21)
    startMillis = currentMillis;
Waveforms.h
#ifndef _Waveforms_h_
#define _Waveforms_h_
#define maxWaveform 4
#define maxSamplesNum 120
static int waveformsTable[maxWaveform][maxSamplesNum] = {
  // Sin wave
    0x7ff, 0x86a, 0x8d5, 0x93f, 0x9a9, 0xa11, 0xa78, 0xadd, 0xb40, 0xba1,
    0xbff, 0xc5a, 0xcb2, 0xd08, 0xd59, 0xda7, 0xdf1, 0xe36, 0xe77, 0xeb4,
    0xeec, 0xf1f, 0xf4d, 0xf77, 0xf9a, 0xfb9, 0xfd2, 0xfe5, 0xff3, 0xffc,
    0xfff, 0xffc, 0xff3, 0xfe5, 0xfd2, 0xfb9, 0xf9a, 0xf77, 0xf4d, 0xf1f,
    0xeec, 0xeb4, 0xe77, 0xe36, 0xdf1, 0xda7, 0xd59, 0xd08, 0xcb2, 0xc5a,
    0xbff, 0xba1, 0xb40, 0xadd, 0xa78, 0xa11, 0x9a9, 0x93f, 0x8d5, 0x86a,
    0x7ff, 0x794, 0x729, 0x6bf, 0x655, 0x5ed, 0x586, 0x521, 0x4be, 0x45d,
    0x3ff, 0x3a4, 0x34c, 0x2f6, 0x2a5, 0x257, 0x20d, 0x1c8, 0x187, 0x14a,
    0x112, 0xdf, 0xb1, 0x87, 0x64, 0x45, 0x2c, 0x19, 0xb, 0x2,
    0x0, 0x2, 0xb, 0x19, 0x2c, 0x45, 0x64, 0x87, 0xb1, 0xdf,
    0x112, 0x14a, 0x187, 0x1c8, 0x20d, 0x257, 0x2a5, 0x2f6, 0x34c, 0x3a4,
    0x3ff, 0x45d, 0x4be, 0x521, 0x586, 0x5ed, 0x655, 0x6bf, 0x729, 0x794
#endif m
That wave looked pretty smooth to me, except the glitches, but I assume that they are when the o-scope redraws the screen because it got to the right edge.
You need to be a LOT more specific than "its performance is not smooth."
double frequency = 50.0;
double displacement = 3;
  for (int j = 0; j <= 21; j++)
      sample = map(frequency - displacement * j, 0, 4095, 0, onefrequencySample);
For values of ‘j’ from 17 to 21 the value of ‘sample’ is zero (50 - 3 * 17 == -1). Perhaps that is causing the problem?
Thank you for your answers.
The output I want to build is the sine wave which performs extension and retraction likes a spring.
However, it performs only the extension moving but not the retraction.
I'd like to rebuild the code referring to the Johnwasser's advice when I'm able to check it with the oscilloscope.
