Sinewave generator
This is my second attempt of a code in order to generate a command voltage to drive a mosfet H bridge configuration which will act as a full wave inverter. I don't know how well this code will work but I'm looking for feedback on it, any help would be greatly appreciated. The delay between each progression of the sine wave is determined by analog command voltage, thus making it variable. As if this works I'm looking to drive an AC motor, and being able to vary the frequency will enable me to control the speed as synchronous speed is = (120*F)/P
where F= frequency and P is poles on the motor.
The pot I'm using to command the time is a 25 turn, so accuracy of this should actually be fairly good.
Thanks again for any feedback.
Nick
/* Inverter Full Wave Bridge Inverter -
SINEWave Inteverter operating at A FREQUENCY DETERMINE BY AN ANALOG VOLTAGE
OUTPUT OF THE ANALOG PINS(3,5,6,9) ARE CONNECTED TO CAPACITORS TO SMOOTH THE TRANSISTION
CREATED BY NICK SEK*/
int POT = 3;//Postive waveform ON TOP MOSFET OF BRIDGE RECTIFIER
int POB = 5;//Positive waveform ON BOTTOM MOSFET OF BRIDGE RECTIFIER
int NOT = 6;//Negative Waveform ON TOP MOSFET OF BRIDGE RECTIFIER
int NOB = 9;//Negative Waveform ON BOTTOM MOSFET OF BRIDGE RECTIFIER
int LED = 8;//LED to indicate circuit is running
int sensorPin = A0;// select the input pin for the potentiometer
int sensorValue = 0;// variable to store the value coming from the sensor
void setup(){
pinMode(POT,  OUTPUT);//Enable POT AS AN OUTPUT
pinMode (POB, OUTPUT);//ENABLE POB AS AN OUTPUT
pinMode (NOT, OUTPUT);//ENABLE NOT AS AN OUTPUT
pinMode (NOB, OUTPUT);//ENABLE NOT AS AN OUTPUT
pinMode (LED, OUTPUT);//ENABLE LED AS AN OUTPUT
void loop(){
  digitalWrite (LED, HIGH);//visual indication that Circuit is running
  sensorValue = analogRead(sensorPin);
  //Postive Side of the SineWave//
  analogWrite(POT & POB, 0); //ENABLE CURRENT PATH FOR POSITIVE WAVEFORM
  delay(sensorValue);//DELAY IS ESTABLISHED BY value from sensor
  analogWrite(POT & POB, 50); //sin11.25*255=approx.= 50
  analogWrite(POT & POB, 100); //sin22.5*255=approx.= 100
  analogWrite(POT & POB,142); //sin33.75*255=approx.= 142
  analogWrite(POT & POB,180); //sin45*255=approx.= 180
  analogWrite(POT & POB,212); //sin56.25*255=approx.= 212
  analogWrite(POT & POB,236); //sin67.5*255=approx.= 236
  analogWrite(POT & POB,250); //sin78.75*255=approx.= 250
  analogWrite(POT & POB,255); //sin90*255 =255
   //Negative Side of the SineWave//
  analogWrite(NOT & NOB, 0); //ENABLE CURRENT PATH FOR NEGATIVE WAVEFORM
  analogWrite(NOT & NOB, 50); //sin11.25*255=approx.= 50
  analogWrite(NOT & NOB, 100); //sin22.5*255=approx.= 100
  analogWrite(NOT & NOB,142); //sin33.75*255=approx.= 142
  analogWrite(NOT & NOB,180); //sin45*255=approx.= 180
  analogWrite(NOT & NOB,212); //sin56.25*255=approx.= 212
  analogWrite(NOT & NOB,236); //sin67.5*255=approx.= 236
  analogWrite(NOT & NOB,250); //sin78.75*255=approx.= 250
  analogWrite(NOT & NOB,255); //sin90*255 =255
Moderator edit: CODE TAGS AGAIN! People, is it really so hard?
This code looks good. It's a little repetitive, though, and that means you have the opportunity to shorten it by using a table (properly, a C array) of sin values and a short function to pick a value from the table and push it to the PWM.
There are lots of examples on the net if you google for "arduino dds"; here's one that shows how you might set up the table in program memory: Arduino sketch for high frequency precision sine wave tone sound synthesis | Adrian Freed
Good luck with your project.
-br
Thanks BR,
New to the programming game and any feedback is great and the idea of saving memory is huge - as I want to extend the ideas of this program, using feedback and a couple variable sensing abilities such as over current for protection... so memory saving is great!
Nick
3 & 5 = 1
You don't really mean "bridge rectifier", do you?
I have to say that I can see no way that your code will work. Absolutely zero.
You may want to go back to basics before tweaking the code further.
No sorry I don't mean rectifier, just in a H bridge configuration... Thanks for seeing that error for me. I'll edit it right away.
And no way it it will work ? Sorry misleading me here, can you give a hint as to why or is it not even worth saving a single bit?
Do you understand the implications of the bitwise AND operation I pointed out in reply #3?
Do you understand PWM?
An H-bridge is essentially two switches that link the output to either the rail or ground. So your top mosfet and your bottom mosfet receive the same signal, 180degrees opposite.
If both of them are on, you short the rail to ground - a very bad thing;
If both of them are off, you have tri-stated the output - a very bad thing if you are looking to output some serious power to a load.
If you want, forget about an external h-bridge, use your output pin which is driven by an internal h-bridge and work out your code first.
Again, there is zero chance your code will work.
