I need some help with this sensor. I can't seem to find any sample code and also am not an experienced programmer. If anyone has some sample code for this sensor your help would be appreciated.
The accel is analog output. Depending on the exact model you have the output will be either 8 or 18 mV/g. You will need an amplifier to bring the signal up to where you can get useful data from an Arduino ADC before sample code will do you any good. Which Arduino are you using? You might be better off looking for an accel that has built in ADC and I2C or SPI output.
