Hi
Getting started with Arduino Duemilanove. I am monitoring a set of no-volt contacts on a relay. I can use the 3.3v supply on the board and measure it on analogue pin 3, the contact position to be monitored using serial print to the monitor.
Single channel voltage logger
connect to
analog 3v3
analog 3
delay = 100 = approx 10 measurements per sec
const int vpin = 3; // v measured
// initialize the serial communications:
// print the sensor values:
Serial.print(analogRead(vpin));
// print a tab between values:
// delay before next reading:
delay(100);
And it works! So that's a good start. When the contact is made the serial monitor reports 686 (bits?), so that's 3.3/5 x 1024. When the relay contacts are open the the data varies between 129 and 1023, probably measuring a floating voltage? Needs to be pulled down to zero (how?). I now want to convert contacts closed to a 1, contacts open to a zero, measurements to occur every 10 seconds (so delay will be one) over a period of one month = 300kb (?). Can the processor store this amount of data or do I need to store to micro-SD?
Looking at some of the other projects going on it's a bit daunting!
