I'm using the Panasonic TQ4-L-5V, which is a single-coil latching relay. I'll be triggering it using an ATtiny to send set/reset pulses. How long should the pulse duration be?
The datasheet specifies a maximum set time of 3 ms (without contact bounce??). Does that mean I should aim for exactly 3 ms, or is something like 5 ms better to ensure reliable switching?
Also, I'm not using a flyback diode across the coil. From what I've read, it's common not to use diodes with single-coil latching relays that only receive brief pulses. Can anyone confirm if this is the correct approach?
Found this now:
Datasheet, page 17: "Regarding the set and reset pulse time, for the purpose of reliable operation under ambient temperature fluctuations and different operating conditions, we recommend setting the coil applied set and reset pulse time to 10 ms or more at the rated coil voltage."
Yes I know.. Thats why I find diodes and single coil latching relays confusing... (on "standard" relay I always use a diode but on pulse relays I dont know...
This post explains it with the conclusion:
We have positive margin on the I/O pin stress rating because 16.8mA < 40mA
So now we know that the ATTINY can drive the relay reliably and it can absorb the inductive kick-back without damage.
Sounds like it.
It's a different relay and he made quite a few assumptions
He never said he actually tried it or has a working circuit to test his theory so it your call.
I'm familiar with that way of reversing polarity but with the possibility of the flyback voltage frying your Arduino I would not tell someone to try it.
Yes TQ2-L-5V. Its a single coil latching relay. (pulse type) According to the datasheet its 20mA. Im planning to set the pulse to the coil direct from the attiny 84
I though it was for the TQ2 he says "Panasonic's TQ2 "
The kickback voltage is directly related to the coil inductance. I see no mention of inductance in his calculations. Again, if you decide to try it let us know what happens.
Zeners.
Will a zener be fast enough?
Will a zener limit the voltage to less than 5V?
As I said his calculations make no mention of inductance so how does he know the kickback voltage. You can try all kinds of tricks if you want. Let us know what happens.
It only takes a few microseconds to burn out a CMOS device.
