Single data line for chip to chip com
Hello
Are there any examples / diagrams available for sending and receiving sync serial data over one data line? I have a chip that accepts up to 10MHz clock and includes a chip select and a single data line.
Thanks for any info!
You may only need a single data line but you also need a common GND connection
hi thanks I meant from an Aurduino UNO minima - The chip and the Aurduino share the same common ground. The chip I am interfacing with includes three signals CLK , DATA and XCS or chip select which I know I can use a GPIO for.
You sure this isn't an SPI interface? Or, something akin to I2C? What chip is it, or is it unmarked?
That would be a three wire (probably half duplex) synchronous bus, similar to SPI, which is a four wire full duplex synchronous bus. Please post a link to the chip data sheet.
Please post a link to the datasheet for the chip
There is a protocol that is very robust called 1 wire CAN. This is a multi master bus that any node can send data. The Arduino uses a 16MHz clock but cannot communicate at 10MHz. The clock is normally divided down inside a chip as it may drive a state machine. Of course with all the great information given such as your magic chip we can only guess.
Hint: All signals need a reference, this is typically ground.
MAS6116 – Stereo Digital Volume Control IC | Micro Analog Systems (mas-oy.com)
Thanks. The MAS6116 data sheet describes the custom serial control protocol in detail.
This could easily be implemented with simple "bit-banged" I/O, and you can find examples for SSI interfaces, which are similar. Search phrase "arduino ssi interface".
I have yet to find an example for ard ... can you point to one? I am new to Ard - can it clock the serial bus?
If you actually have an MAS6116 chip to test, properly mounted on a PCB with all the required decoupling capacitors and other components, please post the details (including a schematic circuit diagram).
I can take a closer look at the data sheet and post some code to try.
Here is what I have for proof of concept
There is no point in coding until you have something to test it with. Follow the manufacturer's recommendations in the data sheet for producing a properly designed test circuit and PCB, or buy the MAS6116 evaluation board.
agree but do you know what pins to use on the ard?
Any digital pins will work.
