Hi, I am stuggeling with the following problem. I have a divice that sends a bipolar singel ended signal (+/- 10V). I want to get this signal into another device, that accepts only differentioal inputs (+10V...-10V). There is no information about a common voltage mode. As far as I know I need to build with Op Amps a little circuit, that transforms this single ended signal into a differential signal. But here, I dont have any clue how to do this, because I dont know how to selsect the correct op amp and the resistors and other stuff around this circuit. I also want to test this on a breadboard, so I cant use smd /smt parts. Do you have any suggestions for this?
(I am beginner in electronics)
1. Please, read this article.
2. Also, look into the following circuit taken from here.
Connect the -10V input to signal ground and feed your single ended signal output into the +10V input.
Grumpy_Mike:
Does this work if both devices are connected to a common ground?
What I told you to do ensures they have a common ground.
Do you have a manual for the device with differential input.
Can you please post a link to it?
Thanks.. Tom..
Since I do not know your voltage requirements I am guessing you are talking audio signals. The conversion can be accomplished with a small transformer. Try this link: https://www.shure.com/en-US/support/find-an-answer/transformers-when-to-use-and-how-does-it-work Here is a transformer source; https://www.lundahltransformers.com/microphone/
Here is another OpAmp circuit.
This response is to help you get started in solving your problem, not solve it for you.
Good Luck & Have Fun!
Gil
