I'm new to this. I have a project where I a looking to read the voltage reported off a lock in amplifier and then get it to read as a digital item on my computer screen. I have a lock in amplifier. I will have one wire providing the demodulated information from the lock-in amplifier to the Arduino Uno.
During the course of time, the voltage will vary and I will need to be able to see, document and plot the variations. It seems like this is perfect for serial monitor and serial plotter. However, I'm not exactly certain how to make this work. I've been looking at projects using these tools, but they seem a bit complicated where as I suspect mine is very simple (perhaps wishful thinking). Where is the best place where I can find the basic information I need without too much extraneous information?
What are You talking about? "Lock amplifier"? Never heard of such aq thing during 45 years of eletrotechnical work? Time for updating me.
Get a 0 to 5 volt signal out of what ever device it is and feed it to an Arduino. Then, as You say, You can use Serial Monitor or Serial plotter.
That's what I needed. As for what a Lock-in amplifier is, it is used for science experiments. I'm working on one now and need an inexpensive way to look for very small changes in electrical output.
To be more clear, my understanding of my lock-in amplifier is that it will send a "report" of the voltage in nano-volts to my arduino. For example. 1.000000024, 1.000000025,
So I need to be able to read these input from the amplifier on the arduino. Does that help out?
A link to the actual device certainly will help you explanation. The more I read, the more I think your device is sending the value read using a serial data communication. Is this correct?
medicrene:
Rene Steinhauer
Oh no, forget that. AVR ADC gives 0 to 1023 plus absolute error may be +/-2 steps.
Railroader:
Arduinos uses 10 bit converters. That gives readings of 0.000, 0.001, 0.002 up to 1.023 volt.
My understanding of the lock in amp is that it will provide the voltage info. i need the Arduino to read the number and print it out. As such, the shortcoming you mention should not be an issue. Am I missing something?
Paul_KD7HB:
Paul
Yes, this is correct. The lock in amplifer can be found on amazon at:
The device is inexpensive, but it comes without any documentation or assistance. I've seen details of it being used, but nothing that helps me figure it out well. I hope to start working with it this week. I think I have a good understanding of what I need to do, but I still don't know how to get the Arduino to "read" the data.
It looks like a manual exist. I qutoe what I found:
Sort by
Most Helpful first
0
votes
Question:
Is there a manual for this product?
Answer:
Yes, you can ask for the manual via the Amazon email, and we will send the pdf version to you.
Shenzhen Taida Century Techno…
Seller · January 6, 2020
