Hello, I want to run a single motor with the L298N motor controller and make both speed and direction adjustments, and I want it to work in the interval I want, I made the necessary codes and circuit for speed and direction adjustment, but I could not do it. Time interval. That's what I did for now.
#define enA 9
#define in1 6
#define in2 7
#define button 4
int rotDirection = 0;
int pressed = false;
pinMode(enA, OUTPUT);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(button, INPUT);
// Set initial rotation direction
digitalWrite(in1, LOW);
digitalWrite(in2, HIGH);
int potValue = analogRead(A0); // Read potentiometer value
int pwmOutput = map(potValue, 0, 1023, 0 , 255); // Map the potentiometer value from 0 to 255
analogWrite(enA, pwmOutput); // Send PWM signal to L298N Enable pin
// Read button - Debounce
if (digitalRead(button) == true) {
pressed = !pressed;
while (digitalRead(button) == true);
delay(20);
// If button is pressed - change rotation direction
if (pressed == true & rotDirection == 0) {
digitalWrite(in1, HIGH);
digitalWrite(in2, LOW);
rotDirection = 1;
delay(20);
if (pressed == false & rotDirection == 1) {
rotDirection = 0;
delay(20);
Please post a picture of a hand-drawn wiring diagram, with pins, connections and parts clearly labeled. Post a link to the motor product page or data sheet.
Also, please describe what should happen when you run the program, and what happens instead.
you button logic is confusing. buttons are typically connected between the pin and ground, the pin configured as INPUT_PULLUP to use the internal pullup resistor which pulls the pin HIGH and when pressed, the button pulls the pin LOW.
"I want" you to post an annotated schematic showing exactly how you have wired it. Be sure all grounds, interconnects, and power sources are shown. Post links to each of the hardware items that gives technical details, links to market places usually do not have that information. The L298N is about the worse choice you can make. You lose about 3 volts to your motor when using it. Is it rated to drive your motor? Without the information "jremington" asked for your odds of getting this answered is slim and none but you could get lucky.
Be smart, before purchasing parts be sure they will do what you want.
Time interval = a segment of time. Per Google: What Is Time Interval? The amount of time between two given times is known as time interval. In other words, it is the amount of time that has passed between the beginning and end of the event."
I used the schema here and did the coding I specified. I'm not the type to do this job, so I don't know much. I want to put a time slot in my coding so that when I run the circuit the motor will run and stop for the time I specify.
I tried the code you sent, but it didn't work exactly as I wanted. When I run the circuit I want to do, for example, after waiting for 5 minutes, it will send a signal to the motor, after working for 1 minute, it will wait for 5 minutes and start again.
Turn on the arduino;
wait a few seconds;
pushes the button;
motor turns to one side for 1 minute and stops.
It only allows turning on and turning in the opposite direction when pressing the button if 5 minutes have passed.
And so? If not,
write your flow..
What I want to do:
Step 1: After turning on the Arduino.
Step 2: The motor will not run for the specified time (example 5 minutes).
Step 3: After the specified time has elapsed, the motor will run for the specified time (example 1 minute).
Step 4: The engine stops.
And it continues to run in this cycle.
