Hi
I am a completely new coder and am trying to wire up single Flora NeoPixel Smart 2 into a diorama. I need the lights to go off in sequence as if it were a nuclear bomb.
I am trying to get
White
White
gradient to fade through the spectrum of orange to yellow to black.
I have the first two flashes but is this last one even possible? I have looked up so many examples of coding gradient in the last six hours and tried a lot of different ones but they’re all for a strip of NeoPixels and seem to complicate it thoroughly.
I have been tinkering with the sample simple NeoPixel coding.
If anyone could and wants to help I’d be really grateful but I understand I might have wilder ideas than I am ready to execute with my currently slim knowledge.
This is the code I have currently:
// NeoPixel Ring simple sketch (c) 2013 Shae Erisson
// Released under the GPLv3 license to match the rest of the
// Adafruit NeoPixel library
#ifdef __AVR__
#include <avr/power.h> // Required for 16 MHz Adafruit Trinket
#endif
// Which pin on the Arduino is connected to the NeoPixels?
#define PIN 5 // On Trinket or Gemma, suggest changing this to 1
// How many NeoPixels are attached to the Arduino?
#define NUMPIXELS 1 // Popular NeoPixel ring size
// When setting up the NeoPixel library, we tell it how many pixels,
// and which pin to use to send signals. Note that for older NeoPixel
// strips you might need to change the third parameter -- see the
// strandtest example for more information on possible values.
Adafruit_NeoPixel pixels(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
#define DELAYVAL 500 // Time (in milliseconds) to pause between pixels
// These lines are specifically to support the Adafruit Trinket 5V 16 MHz.
// Any other board, you can remove this part (but no harm leaving it):
#if defined(__AVR_ATtiny85__) && (F_CPU == 16000000)
clock_prescale_set(clock_div_1);
#endif
// END of Trinket-specific code.
pixels.begin(); // INITIALIZE NeoPixel strip object (REQUIRED)
pixels.clear(); // Set all pixel colors to 'off'
// The first NeoPixel in a strand is #0, second is 1, all the way up
// to the count of pixels minus one.
for(int i=0; i<NUMPIXELS; i++) { // For each pixel...
// pixels.Color() takes RGB values, from 0,0,0 up to 255,255,255
// Here we're using a moderately bright green color:
pixels.setPixelColor(i, pixels.Color(243, 255, 255));
pixels.show(); // Send the updated pixel colors to the hardware.
delay(DELAYVAL); // Pause before next pass through loop
pixels.setPixelColor(i, pixels.Color(0, 0, 0));
pixels.setPixelColor(i, pixels.Color(255, 255, 255));
#define DELAYVAL 900 // Time (in milliseconds) to pause between pixels
pixels.setPixelColor(i, pixels.Color(255, 68, 0));
#define DELAYVAL 1500 // Time (in milliseconds) to pause between pixels
