Single Propeller Drone Project
Hello,
We have 4 servo,gyro,servo driver and arduino uno for this project.We want to control those servos with gyro and there we found an arduino code for 2 servo motor,my question is that how can ı modify this code to work with 4 servo?
// 2 servo planar stabilization system
// wp
// Jan 2016
// Based on Jeff Rowber’s work found at
// https://github.com/jrowberg/i2cdevlib/blob/master/Arduino/MPU6050/MPU6050.cpp
// Use at your own risk.
// This code is placed under the MIT License (MIT)
// Copyright (c) 2016 woojay poynter
//Permission is hereby granted, free of charge, to any person obtaining a copy
//of this software and associated documentation files (the “Software”), to deal
//in the Software without restriction, including without limitation the rights
//to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
//copies of the Software, and to permit persons to whom the Software is
//furnished to do so, subject to the following conditions:
//The above copyright notice and this permission notice shall be included in all
//copies or substantial portions of the Software.
//THE SOFTWARE IS PROVIDED “AS IS”, WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
//IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
//FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
//AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
//LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
//OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
//SOFTWARE.
// Servo Connection
// BROWN - gnd
// red - 5v
// yellow - d10 (pwm on Sero 1)
// - d11 (servo 2)
// MPU Connection
// VCC - 5v
// GND - GND
// SCL - A5 (w/ 10k PuR)
// SDA - A4 (w/ 10k PuR)
// INT - D2 (not used)
#include <Servo.h>
#include “I2Cdev.h”
#include “MPU6050_6Axis_MotionApps20.h”
//#include “MPU6050.h” // not necessary if using MotionApps include file
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
#include “Wire.h”
#endif
#define LED_PIN 13
bool blinkState = true;
Servo Servo1; // First Servo off the chassis
Servo Servo2; // Second Servo off the chassis
int Servo1Pos = 0;
int Servo2Pos = 0;
float mpuPitch = 0;
float mpuRoll = 0;
float mpuYaw = 0;
// define MPU instance
MPU6050 mpu; // class default I2C address is 0x68; specific I2C addresses may be passed as a parameter here
// MPU control/status vars
uint8_t mpuIntStatus; // holds actual interrupt status byte from MPU
uint8_t devStatus; // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize; // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount; // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO storage buffer
// orientation/motion vars
Quaternion q; // [w, x, y, z] quaternion container
VectorInt16 aa; // [x, y, z] accel sensor measurements
VectorInt16 aaReal; // [x, y, z] gravity-free accel sensor measurements
VectorInt16 aaWorld; // [x, y, z] world-frame accel sensor measurements
VectorFloat gravity; // [x, y, z] gravity vector
float ypr[3]; // [yaw, pitch, roll] yaw/pitch/roll container and gravity vector
// relative ypr usage based on sensor orientation when mounted, e.g. ypr[PITCH]
#define PITCH 1 // defines the position within ypr variable for PITCH; may vary due to sensor orientation when mounted
#define ROLL 2 // defines the position within ypr variable for ROLL; may vary due to sensor orientation when mounted
#define YAW 0 // defines the position within ypr variable for YAW; may vary due to sensor orientation when mounted
// === INITIAL SETUP ===
Servo1.attach(10); // attaches the servo on D11 to the servo object
Servo2.attach(11); // Second servo on D11
delay(50);
Servo1.write(0); // These are command checks to see if the servos work and
Servo2.write(60); // to help w/ the initial installation.
delay(500); // Make sure these movements are clear from the rest of the chassis.
Servo1.write(180);
Servo2.write(120);
Servo1.write(0);
Servo2.write(90);
// join I2C bus (I2Cdev library doesn’t do this automatically)
Wire.begin();
TWBR = 24; // 400kHz I2C clock (200kHz if CPU is 8MHz)
#elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
Fastwire::setup(400, true);
#endif
while (!Serial); // wait for Leonardo enumeration, others continue immediately
// initialize device
Serial.println(F(“Initializing I2C devices…”));
mpu.initialize();
// verify connection
Serial.println(F(“Testing device connections…”));
Serial.println(mpu.testConnection() ? F(“MPU6050 connection successful”) : F(“MPU6050 connection failed”));
// load and configure the DMP
Serial.println(F(“Initializing DMP”));
devStatus = mpu.dmpInitialize();
// INPUT CALIBRATED OFFSETS HERE; SPECIFIC FOR EACH UNIT AND EACH MOUNTING CONFIGURATION!!!
mpu.setXGyroOffset(118);
mpu.setYGyroOffset(-44);
mpu.setZGyroOffset(337);
mpu.setXAccelOffset(-651);
mpu.setYAccelOffset(670);
mpu.setZAccelOffset(1895);
// make sure it worked (returns 0 if so)
if (devStatus == 0)
// turn on the DMP, now that it’s ready
Serial.println(F(“Enabling DMP”));
mpu.setDMPEnabled(true);
// enable Arduino interrupt detection
Serial.println(F(“Enabling interrupt detection (Arduino external interrupt 0)”));
mpuIntStatus = mpu.getIntStatus();
// get expected DMP packet size for later comparison
packetSize = mpu.dmpGetFIFOPacketSize();
// ERROR!
// 1 = initial memory load failed, 2 = DMP configuration updates failed (if it’s going to break, usually the code will be 1)
Serial.print(F("DMP Initialization failed code = "));
Serial.println(devStatus);
// configure LED for output
pinMode(LED_PIN, OUTPUT);
} // setup()
// === MAIN PROGRAM LOOP ===
void loop(void)
processAccelGyro();
} // loop()
// === PROCESS ACCEL/GYRO IF AVAILABLE ===
void processAccelGyro()
// Get INT_STATUS byte
// get current FIFO count
fifoCount = mpu.getFIFOCount();
// check for overflow (this should never happen unless our code is too inefficient)
if ((mpuIntStatus & 0x10) || fifoCount == 1024)
// reset so we can continue cleanly
mpu.resetFIFO();
Serial.println(F(“FIFO overflow!”));
return;
if (mpuIntStatus & 0x02) // otherwise continue processing
// check for correct available data length
if (fifoCount < packetSize)
return; // fifoCount = mpu.getFIFOCount();
// read a packet from FIFO
mpu.getFIFOBytes(fifoBuffer, packetSize);
// track FIFO count here in case there is > 1 packet available
fifoCount -= packetSize;
// flush buffer to prevent overflow
mpu.resetFIFO();
// display Euler angles in degrees
mpu.dmpGetQuaternion(&q, fifoBuffer);
mpu.dmpGetGravity(&gravity, &q);
mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);
mpuPitch = ypr[PITCH] * 180 / M_PI;
mpuRoll = ypr[ROLL] * 180 / M_PI;
mpuYaw = ypr[YAW] * 180 / M_PI;
mpu.resetFIFO();
// blink LED to indicate activity
blinkState = !blinkState;
digitalWrite(LED_PIN, blinkState);
mpu.resetFIFO();
Servo1.write(-mpuPitch + 90);
Servo2.write(mpuRoll + 90);
//delay(10);
mpu.resetFIFO();
} // if (mpuIntStatus & 0x02)
} // processAccelGyro()
I attached the proposal of the project
carholt2016.pdf (692 KB)
Please read the "How to use this forum" post and follow the directions. Edit your post to add code tags.
Hi burakarda,
A singlecopter... 8) .
The principle is the same for any multi-rotor/drone configuration, whether it's a singlecopter, bicopter, tricopter, quadcopter, etc..., the only difference is in the motor/servo mixing.
For a Singlecopter 1M4S (1 motor, 4 servos) you need 5 channels and the motor mixing looks something like this:
| Channel | Throttle | Roll PID | Pitch PID | Yaw PID | | - | - | - | - | - | | 1 (motor) | 100% | 0% | 0% | 0% | | 2 (servo) | 0% | -100% | 0% | 100% | | 3 (servo) | 0% | 0% | 100% | 100% | | 4 (servo) | 0% | 100% | 0% | 100% | | 5 (servo) | 0% | 0% | -100% | 100% |
Channel 1 is the motor and is connected to the throttle. The reason for the +100% and -100% for roll and pitch PID outputs, is because the opposing servos are a mirror image of each other, but must drive the rudders in the same direction. Yaw on the other hand, moves the opposing rudders in opposite directions.
