I've seen many (probably the majority) of articles that just have a single resistor between Uno and TFT pins.
Surely these can't be correct. It takes a pair of resistors to form a voltage divider to level shift from 5V down to 3.3V
All a single resistor will do is reduce the current, not change the voltage.
What am I missing here?
What happens to the voltage drop across the resistor as the current changes? Look at Ohm's Law as the reference.
Some displays only need Vcc to that pin to work properly. Changing that voltage in a very small range will change the contrast. Changing the Vcc will also change the operation of the LCD. That is from experience, not from any book.
@gilshultz,
Actually, I measured the input impedence to one of the TFT pins and it's greater than 20MOhm, so a 1k resistor doesn't even drop the current. I don't see how a single resistor makes any difference.
@LarryD,
Here are a sample of posts/articles that propose a single resistor:
TFT 1K Resistor
Another 1K resistor
Yet another proposing a single Resistor
And here is one that has a true voltage divider:
Voltage Divider solution
A simple google search brings up many, many more examples with a vast majority just using/proposing a single resistor solution.
Not sure how a single 1K resistor makes any difference when the TFT Pin has a resistance greater than 20M
Hello Larry,
Having thought more about this ( and your illustrative circuit diagram was very helpful ), I can see how this can work with a single resistor.
I had been measuring the resistance between the TFT logic input and ground. This was an incorrect assumption on my part. The diode to 3.3v makes all the difference.
Thanks
