Hey,
I wonder if someone can see where i am going wrong with my IF statements.
I keep getting this error when compiling:
Arduino/sinric_alexa_frontdoor_with_CT/sinric_alexa_frontdoor_with_CT.ino/sinric_alexa_frontdoor_with_CT.ino.ino: In function 'void loop()':
sinric_alexa_frontdoor_with_CT.ino:149: error: invalid operands of types 'double' and 'const char [2]' to binary 'operator>'
if (Irms > "1"){
Arduino/sinric_alexa_frontdoor_with_CT/sinric_alexa_frontdoor_with_CT.ino/sinric_alexa_frontdoor_with_CT.ino.ino: At global scope:
sinric_alexa_frontdoor_with_CT.ino:157: error: expected unqualified-id before 'if'
if(isConnected) {
exit status 1
Here is my code:
Version 0.3 - March 06 2018
#include "EmonLib.h"
EnergyMonitor emon1;
#include <Arduino.h>
#include <ESP8266WiFi.h>
#include <ESP8266WiFiMulti.h>
#include <WebSocketsClient.h> // https://github.com/kakopappa/sinric/wiki/How-to-add-dependency-libraries
#include <ArduinoJson.h> // https://github.com/kakopappa/sinric/wiki/How-to-add-dependency-libraries
#include <StreamString.h>
ESP8266WiFiMulti WiFiMulti;
WebSocketsClient webSocket;
WiFiClient client;
const int ledPin = D1;
#define MyApiKey "*removed*" // TODO: Change to your sinric API Key. Your API Key is displayed on sinric.com dashboard
#define MySSID "*removed*" // TODO: Change to your Wifi network SSID
#define MyWifiPassword "*removed*" // TODO: Change to your Wifi network password
#define HEARTBEAT_INTERVAL 300000 // 5 Minutes
uint64_t heartbeatTimestamp = 0;
bool isConnected = false;
void setPowerStateOnServer(String deviceId, String value);
//void setTargetTemperatureOnServer(String deviceId, String value, String scale);
// deviceId is the ID assgined to your smart-home-device in sinric.com dashboard. Copy it from dashboard and paste it here
void turnOn(String deviceId) {
if (deviceId == "*removed*") // Device ID of first device
Serial.print("Turn on device id: ");
Serial.println(deviceId);
digitalWrite(ledPin, LOW);
Serial.print("Turn on for unknown device id: ");
void turnOff(String deviceId) {
Serial.print("Turn off Device ID: ");
digitalWrite(ledPin, HIGH);
Serial.print("Turn off for unknown device id: ");
void webSocketEvent(WStype_t type, uint8_t * payload, size_t length) {
switch(type) {
case WStype_DISCONNECTED:
Serial.printf("[WSc] Webservice disconnected from sinric.com!\n");
case WStype_CONNECTED: {
isConnected = true;
Serial.printf("[WSc] Service connected to sinric.com at url: %s\n", payload);
Serial.printf("Waiting for commands from sinric.com ...\n");
case WStype_TEXT: {
Serial.printf("[WSc] get text: %s\n", payload);
// Example payloads
// For Switch or Light device types
// {"deviceId": xxxx, "action": "setPowerState", value: "ON"} // https://developer.amazon.com/docs/device-apis/alexa-powercontroller.html
// For Light device type
// Look at the light example in github
DynamicJsonBuffer jsonBuffer;
JsonObject& json = jsonBuffer.parseObject((char*)payload);
String deviceId = json ["deviceId"];
String action = json ["action"];
if(action == "setPowerState") { // Switch or Light
String value = json ["value"];
if(value == "ON") {
turnOn(deviceId);
turnOff(deviceId);
else if (action == "SetTargetTemperature") {
else if (action == "test") {
Serial.println("[WSc] received test command from sinric.com");
case WStype_BIN:
Serial.printf("[WSc] get binary length: %u\n", length);
emon1.current(A0, 111.1); // Current: input pin, calibration.
WiFiMulti.addAP(MySSID, MyWifiPassword);
Serial.print("Connecting to Wifi: ");
Serial.println(MySSID);
// Waiting for Wifi connect
while(WiFiMulti.run() != WL_CONNECTED) {
Serial.print(".");
if(WiFiMulti.run() == WL_CONNECTED) {
Serial.println("");
Serial.print("WiFi connected. ");
Serial.print("IP address: ");
pinMode(ledPin, OUTPUT); // initialize digital ledPin as an output.
delay(10);
digitalWrite(ledPin, HIGH); // Wemos BUILTIN_LED is active Low, so high is off
// server address, port and URL
webSocket.begin("iot.sinric.com", 80, "/");
// event handler
webSocket.onEvent(webSocketEvent);
webSocket.setAuthorization("apikey", MyApiKey);
// try again every 5000ms if connection has failed
webSocket.setReconnectInterval(5000); // If you see 'class WebSocketsClient' has no member named 'setReconnectInterval' error update arduinoWebSockets
webSocket.loop();
double Irms = emon1.calcIrms(1480); // Calculate Irms only
Serial.println(Irms);
if (Irms > "1"){
setPowerStateOnServer("deviceid", "ON");
setPowerStateOnServer("deviceid", "OFF");
if(isConnected) {
uint64_t now = millis();
// Send heartbeat in order to avoid disconnections during ISP resetting IPs over night. Thanks @MacSass
if((now - heartbeatTimestamp) > HEARTBEAT_INTERVAL) {
heartbeatTimestamp = now;
webSocket.sendTXT("H");
// If you are going to use a push button to on/off the switch manually, use this function to update the status on the server
// so it will reflect on Alexa app.
// eg: setPowerStateOnServer("deviceid", "ON")
void setPowerStateOnServer(String deviceId, String value) {
JsonObject& root = jsonBuffer.createObject();
root["deviceId"] = deviceId;
root["action"] = "setPowerState";
root["value"] = value;
StreamString databuf;
root.printTo(databuf);
webSocket.sendTXT(databuf);
Any help would be much appreciated.
Regards,
Edd
