Sinusodial Perameters and SPI drop outs?
Hello!
I have a small project whereby one UNO will send a sine wave to another over SPI. It has mostly gone well and i am receiving the sine wave on the slave side. I have two main issues however, one is that the sinusoidal equation i am using is incorrect for the amplitude or range that i require. I need the maximum value to be 4096 and minimum to be 820 (this is because i plan on using a 12 bit dac some time in the future). I want this to increment on every whole number to give me 3276 total increments, this isnt currently happening in my system. The code for this can be seen below.
for(int x=0;x<3276;x++){ // for x 0-3276 increment x, 3276 = total number of potential increments
  float y = float (x)/100;
  buff = ((sin(y)*1638)+2458); // Min = 820 = 1V, Mid point = 2458 = 3V, Max = 4096 = 5V, Amplitude = 1638
The other issue is that the recieved signal will randomly cut out and show random values at seemingly random intervals as seen in the picture below.
I would massively appreciate any help.
Thank you!
My full code is:
/* Master */
// SPI Test for 12 BIT DAC
#include <SPI.h>
const int ChipSelect = 10; //SS Pin 10
byte dacPrimaryByte; //Most significant byte
byte dacSecondaryByte; // Least significant byte
uint16_t buff; // 4 zero's + 12 bit value output from Sine wave function
  pinMode (ChipSelect, OUTPUT); // SS Output
  digitalWrite(ChipSelect, HIGH); // SS High - Not active
  SPI.begin(); // Sets SPI perameters
  Serial.begin(9600); // Set baud rate
  SPI.setClockDivider(SPI_CLOCK_DIV8); // Slow the clock
  float y = float (x)/1000;
// Need to work out the optimum perameters for the above...
   byte DACconfig = 0b00110000; // 0011 is most significant 4 bits of PrimaryByte, this will activate the DAC Register, Disable the buffer, Activate gain of 1x, Activate operating mode.
   uint16_t dacSecondaryByteMask = 0b0000000011111111; // 8 LSB mask to single out Secondary Byte
   byte dacPrimaryByte = byte(buff >> 8) | DACconfig; // Shift 12 bit buff value 8 places leaving 4 bits in the first byte. OR with DACconfig to have 4 config bits and first 4 data bits, 1V (min) = 820, 5v (max) = 4096, 3V (mid) = 2458
   byte dacSecondaryByte = byte(buff & dacSecondaryByteMask); // Buff AND Secondary Byte mask leaves only the final 8 bits of Buff. 2 Bytes will be concatenated on slave end
    digitalWrite(ChipSelect, LOW); // SS Low = Active
    SPI.transfer(dacPrimaryByte); // Transfer most significant byte
    SPI.transfer(dacSecondaryByte); // Transfer least significant byte
    digitalWrite(ChipSelect, HIGH); // SS High = End of transfer
/* Slave */
#include <SPI.h>
byte storage [8]; // Storage byte for SPI data register
volatile byte pos; // Position within storage byte
volatile boolean process; // Has byte been processed?
uint8_t buff[2]; // Buffer for transfered data
word output_2byte; // 2 Concatenated bytes
word output_12bit; // Concatenated bytes - 4 DAC Config bits
int minout = 819; // Minimum Output_12bit
int maxout = 4096; // Maximum Output_12bit
  pinMode(MISO,OUTPUT);
  SPCR |= _BV(SPE); // Enable Slave mode
  SPCR |= _BV(SPIE); // Enable interrupts
  pos = 0; // Set pos to bit 0
  process = false; // Process not yet occured
ISR(SPI_STC_vect) // Interrupt service routine
  byte gathered = SPDR; // Gathered = SPI data register
  if( pos < sizeof storage) // If position within storage is smaller than size of storage
      storage[pos++] = gathered; // Go to next bit in storage byte. Storage byte is equal to SPI data register value
    process = true; // Else the data in SPI data register has been processed
  if( process )
    memcpy(buff,&storage,8); // Copy data from storage to buffer byte array
   // Serial.println(buff[0]);
   // Serial.println(buff[1]);
   output_2byte = word(buff[0], buff[1]); // Concatenate 2 bytes
   output_12bit = output_2byte & 0xFFF; // Remove the first 4 MSB's
   Serial.println(output_12bit, '\n'); // Print output and start new line
    storage[pos] = 0; // Reset storage
    pos = 0; // Reset position
    process = false; // Reset process
   // delay(90);
How do You prevent the slave to be overloaded and miss processing?
You can't read from the ISR buffer like that. You must disable interrupt to be sure You get a hole 16 bit int when reading.
