Sinusoidal lighting system
I'm new to this, that is my code about sinusoidal lighting system. it doesn't work when i applied on the lamp, but works in serial plotter. it can make the sinusoidal wave.
#include <Arduino.h>
// Define the PWM pin
const int pwmPin = 4; // pin number
// Parameters for the sinusoidal function
const float amplitude = 255.0; // Max amplitude for 8-bit PWM
const float period = 1 * 3600.0; // Period of the sinusoidal wave in seconds (1 hour)
const float frequency = 1.0 / period; // Frequency in Hz
const float phase = -PI/2; // Phase shift in radians
// Time calculation
unsigned long startTime;
// Initialize the PWM pin
ledcAttach(pwmPin, 5000, 8); // pin, frequency, resolution
pinMode(pwmPin, OUTPUT);
// Record the start time
startTime = millis();
// Calculate the elapsed time in seconds
unsigned long currentTime = millis();
float t = (currentTime - startTime) / 1000.0;
// Calculate the sinusoidal value
float y = amplitude/2 * (1 + sin(2 * PI * frequency * t + phase));
// Set the PWM value
ledcWrite(0, (int)y);
Serial.println((int)y);
// Small delay to allow smooth PWM changes
delay(100);
for inserting code use code-tags
void setup(){
  // configure LED PWM functionalitites
  ledcSetup(ledChannel, freq, resolution);
  // attach the channel to the GPIO to be controlled
  ledcAttachPin(ledPin, ledChannel);
What Arduino are you using, how is the lamp wired, and what does this function do?
Please use code tags when posting code.
Hi, @fahmiammm03
Welcome to the forum.
What model Arduino are you using?
What is the lamp you are trying to control?
Have you written some simple ON/OFF code to prove you have control of the lamp?
Thanks.. Tom.. :smiley: :+1: :coffee: :australia:
